Connecting a monitor (Atomos Shinobi) to the SDI terminal of the C200 the OSD setting to OFF has no effect. It only works for HDMI output. I read somewhere on a forum that this appeared to be a bug. Do you have the same experience and is there a workaround to get a clean feed from the SDI terminal?
Problem solved. The setting "SDI Output Always On" was ON. When set to OFF the OSD setting will work for the SDI output.
