NLE Performance, AVCHD vs. transcoded ProRes
jshbckr
Wondering what most people here do. I've been using ClipWrap to wrap MTS files at MOV, but I've noticed that both MTS and MOV haven't been performing all that well in Premiere Pro CS6. I'm using a 2012 MacBook Pro with a 7200RPM drive (footage) and SSD for the OS. I also get poor playback when I'm using my Thunderbolt RAID.
I was excited for Premiere's ability to natively edit AVCHD footage, but it is looking like the ProRes files perform significantly better. Maybe I'm doing something wrong, though.
Thoughts?
Are you using an Nvidea vid card ? and if so, do you have the mercury playback engine turned on?
I've been running CS5.5 on a PC (no mac) and did a quick test when I first got it. 8 layers of full hd (AVCHD) running in real time even with a few effects.
But add MB Looks and it seems to grind and stutter.
Wow, when I checked the pull-down menu I realized that it was enabled but not the CUDA option. Just enabled that and it's a complete 180. Thank you! That's exactly what I needed!
I'm using Mac Premiere 5 and after effects 5.5 and here's what I noticed.
I use Clipwrap to convert the .MTS strictly for preview purposes. The native .MTS file works a LOT better and quicker in both Premiere and After Effects than the converted Clipwrap file. The clipwrap file is much slower when scrolling through the timeline. Not sure why. So yeah. Clipwrap .Movs for preview purposes, but .MTS for editing.
Interesting. Well I guess I can still use ClipWrap for previewing, like you said, but I'm on Mountain Lion and getting to the MTS files is a hassle. Mountain Lion sees the AVCHD folder as a file, so you have to jump through hoops of "Show Package Contents" to uncover the STREAM folder containing the MTS files. Anyone on ML have a workflow solution?
Unfortunately, I'm on a first generation Mac 8 core which is not even 5 years old, and Apple does not support Mountain Lion for it, which would have been nice since it supports .mts.
So for me, it's just Clipwrap to preview and work with the .MTS in the Editing programs. But yes, at least on my computer, the .MTS works a lot better and less sluggish than the Clip Wrap quicktimes.
I am on CS 5.5, but I did notice something else strange about Clip Wrap. On CS 5, certain clip wrap quicktimes would crash Premiere or After Effects every time, but when I moved up to CS 5.5, those same clips worked fine. I'm not on CS6 yet, but maybe the Clip Wrap quicktimes might work even better no. Not sure.
This is a hassle, and worse, on long clips, it will ruin your audio. The AVCHD folder contains files other than the .MTS files, and those files aren't just junk; they contain the meta-data that Premiere needs to stitch together clips that get broken up (due to the filesize limit). So if you just load the .MTS files, then on any clip that goes over the file size limit (11 mins or so, generally), you will get an audio glitch at the join.
It's far better to copy over the whole PRIVATE folder, and import THAT FOLDER into PP.
Hey guys,
Saw this thread, and I wanted to jump in. We've spent the last few releases of ClipWrap improving Premiere rewrap playback. If you haven't already, make sure to try your workflow out again with ClipWrap 2.5.8 - we introduced a pretty big playback improvement on mercury. In addition there's a hidden switch you can flip to improve the thumbnailing and other "non-editorial" operations... check out this blog post here: http://www.divergentmedia.com/blog/fullpost/clipwrapppro6
As always, if things aren't workign well for you, please let us know. support@divergentmedia.com
Thanks,
mike
Mike Woodworth
mike@divergentmedia.com
