Danielvilliers
Yes the fix pattern noise is the real problem about this camera. I have not tried to remove it until now, but others have reported that Neatvideo did a very good job about it.
Not sure what format the Ninja save in but,One thing you really have to think about is how you will remove the pulldown if you use the Ninja.
From some report I heard people have been saying that the D7100 video image is a little sharper than the D7100.
Huh?
And tell us the answer, already!
I suggest confirming this before you buy a camera and recorder.The Ninja 2 does the pull down at least on the D800, I think it should be the same for the D7100. I could have bought the Ninja 1 much more cheaply but I don't know if it is compatible with the D7100.
I hope that this information is correct. My concern stems from three things. 1. I have a D5200 and the HDMI out is only 24 PsF when recording, which means I need to remove the pulldown while recording or in post. 2. The Ninja 1 cannot remove a pulldown; the Ninja 2 can but it's sounds a little wonky. http://atomos.activehosted.com/kb/article/input-sources/g5 3. Atomos' camera compatibility list has "720p/60 output only" next to the D7100. http://www.atomos.com/discovery-what-cameras/ That all said, good luck and I hope it DOES work!I already have the camera as a back-up to my D800 which work perfectly with the Ninja 2. I have seen some example like this one http://www.youtube.com/watch?v=xFsvEAiWr_8 which is very encouraging with the Ninja (look at the shadows lift with the lens cap) and this http://www.youtube.com/watch?v=zUrQCKYIsFA . I have also seen report that it does work well (no talk about pull down) on Atomos forum with only one issue. There is a sound sync problem like there was before with the D800. I think it will get addressed by a firmware update like they did with the D800.
