Next: 4K Recorder 30p/60p 10-12Bits 4:2:2, uncompressed, prores, H265 & PC 1.395-3K€
Hi shooter, 900€ will be the approx. price for 32Gb of ram, 16GB is currently priced at website. 32GB is for custom builds and only available for 5th gen processors.
Weight without battery is 1.5Kg. Batt weight varies from model to model
All is listed on the website, just go to http://www.cinemartin.com/next/buy/ then scroll down and on the right side you'll the the configuration area
Currently 8GB is 195€ with Cinemartin verification or 295€ for manufacturer certified, then 16GB is 390€ and 590€ respectivaly
I dont understand what do you mean by "And from your €3.995 offer?"
and about the 32GB option, where is it? If I go with one model of 8GB in your website, how much for 32GB option?
32GB is only available for 5th gen processor. 5th gen processor are only 10-20% faster but with support for 32GB. Predefined models comes with 4th gen processor that supports up to 16GB.
So, if you want 32GB you'll need to go for a custom build.
Basically if you need the
NEXT HDMI + DUAL SDI​
4K60P 10-Bit 444, 3D​
MAC OS COMPAT​
you'll need to add + 510€ for 32GB (900 - 390) and add + 200€ for the 5th gen processor base so 3995 + 710 = 4705€ but this is not the case as predefined models have a special price and currently as an option only have the 5th gen base (for +250€). So currently you'll need to go for custom build to get a 32GB model.
If you're interested in this above or similar configuration we can give to you a better price (as a forum member) with 32GB, simply configure it on the web and send an email to our sales manager (Angelo) with a screenshoot or similar, that you're feel free to post here too.
Thank you. I'll be waiting for your testing on Resolve. But, you forgot the weight with battery included... Both battery options, by the way, please.
Hi for resolve I currently have a dell 2414q 4k display on the repair service center, so currently I have no external display with display port. Would you like for me to install and show you Resolve on NEXT unit without ext. monitor or can you wait ? dell told me that they need to wait for the new firmware that will be out in about a month or so.
For the weight I will send you some pictures tomorrow with a scale.
533 grams for which battery? Is the other battery type in the same weight range? Isn't it possible to find a lighter power setup?
As you wish. But, do we really need the 4k monitor? No, isn't it?
We only need to figure out the accuracy of this information if it is compatible with Resolve 11 demanding 6GB RAM for GPU card (or not):
http://forum.blackmagicdesign.com/vi...hp?f=3&t=29034
We didnt find. A power to get a labtop with a hight end video workstation in less than 500gr ? no, just connecting to the wall will give you 500gr less. The other batt is 600gr,
there wil be probably lighter but with less capacity for 350-400 gr
I will try this weekend, but im not sure if redolve will be able to run on a hd panel, where most today computer displays are 1920x1080.. I will tell you what happens
but that is also the idea, isn't it? to see if Resolve will run with and in this device...
Hi, yes, I was able to install and run Resolve 11.3, but I never used Resolve, and I dont know how to load clips, Ther'es simply the Library and Media pool panels but right click does not show load clip or import clip/s or like
So, basically
A)Yes, NEXT is able to run davinci resolve
B)Anyone can tell me how to load some clips (preferably uncompressed .avi clips within) ?
I dont know how to import load a clip, simply tell me how and I will go for.. No one can tell me hiw to load a clip from resolve .. but it will work with 4k as were working with premiere. Weight 1.390 without battery
