A couple of days ago I saw people commenting on Mr Keaton's post about the new firmware for the Odyssey 7Q(+) and some of those comments included wishes about new features on a new recorder from Convergent Design. I have the first version of the Odyssey, the 7Q, and it has served me well. My only real "complaints" are the size (yes it's small but it would be lovely if it was smaller) and the screen brightness. When reading those comments I started thinking about what I would really like to have in an external recorder. Since I own the Varicam LT and FS700 and mostly work alone, I started thinking about if there might be a completely different design that might work better for me. Since the EVA1 is about to be released soon and will have raw recording capabilities paired with an external recorder, I was also thinking about if it would be possible to make something that works with it and other similar models (size and raw recording capabilities).
One thing that can be a problem with smaller cameras, is how to power accessories like an external recorder, monitor, wireless follow focus and so on. Another thing is that you'd also need a power cable going into the external recorder even if you power it from a larger camera.
So I came up with an idea (that I'm certain someone else has thought about too) on how to make another type of external recorder that would work on many cameras.
The idea is simple:
1. Make it the same size as a V-lock battery plate, to be sandwiched between the camera and the battery, like this but probably bigger: http://www.idxtek.com/products/md-nbv/
2. Let the camera side be changeble to adapt for different battery types, and make that adapter with a bulit in and hight adjustable rod support, since other battery mounts probably aren't as sturdy as V-lock or Gold-mount. (Or maybe a detachable rod support on the recorder, and a cable with a battery adapter going from the recorder to the camera would be better. This would then use one of the power outputs, but it needs the V-lock/Gold mount for it to be an interesting option for use on larger cameras.)
3. Have a power input (for power if not using batteries), some power outputs and some SDI/HDMI inputs and outputs on the recorder, and a simple menu control with a small LCD.
4. Make it with SSD slots, like now, or some other media with high write speeds.
5. Make it controllable with an app via wifi.
6. Make a separate high quality monitor with a touch screen, which can display the image and control the recorder as an option for those who for some reasons prefer not to use wifi. This should be an accessory.
The reason why I would prefer something like this is that it would hopefully (depending on size) let me have it on my camera "all the time" and will take up less space than the recorders available now. Cables are a PITA and I would really like to minimize the use of those as far as possible. The only real disadvantages (that I can think of right now) with this is that it might be a bit more difficult to control and also more difficult to look at recorded material (but if you have the monitor accessory or another monitor connected via SDI, it isn't), on the other hand maybe something could be played on the small LCD. The advantages are size, less cables, placement and that you can use whatever monitor you prefer. Another thing is that it would make it easier to record raw on a Varicam LT on a steadicam or gimbal. Like it is now it needs two SDI-cables to output high speed or 12-bit raw. The best place to put the O7Q on a steadicam is where the monitor should be, but the O7Q isn't really made for that sort of work IMO, because the screen isn't bright enough, and it also needs two SDI-cables to go through the post to the recorder. I think it would be better to have the possibility to have the recorder on the camera (without creating a "Franken-rig") and using something different as a monitor.
Simply put it would be something like the Codex on the Varicam Pure, but with some cables and of course different capability.
Is it a good idea or would most people not buy it?
I'm pretty sure I'd buy something like this if it was available and get a separate bright monitor for when I need one.
The idea is simple:
