Eric Coughlin
If you can use the Blackmagic EVF, does anyone know if it is possible to use a USB splitter (or if the Blackmagic EVF has a USB output) to be able to use both the Blackmagic EVF and Canon LCD at the same time?
but your noise is enlarged. I think you're effectively in the same place as if you use a FF lens and no cropI wonder if there is anything preventing you from using the speedbooster with the super35 or super16 modes? Then you'd get the extra stop of light, plus the higher native ISO's.
Pretty much. Plus speedboosters are often known to reduce sharpness and can have other negative image effects.but your noise is enlarged. I think you're effectively in the same place as if you use a FF lens and no crop
