Adam J McKay Veteran Mar 21, 2011 #2 Does anybody know what happened to the variable bit rate option? It seems it has disappeared completely from the recent firmware hacks.
thekreative Veteran Mar 23, 2011 #3 Different Hack. The Vari-Frame rate was Hudson's Hack. This is a new compile based on hudson's but reversed engineered from the sounds of it , to fix some bugs that Hudson's had.
A aj_newman Member Mar 28, 2011 #4 Bit rates / Q-scale: Is on the todo list - one of the reasons that the code is still in Beta testing. AJ
