Indisystem
DVXuser Sponsor
Revolution or Evolution?
When it comes to a camera slider under a hundred bucks, who cares!
Introducing the all new indiSLIDERmini.
24” of compact, light-weight, fast set-up sliding. Everything that is needed to make ‘those’ shots you’ve seen on other peoples’ work, is available now for $99.
With the new indiMOUNT on the glide carriage, no fluid head is needed. Attach the camera to the mounting puck and attach into the holder. This also allows for the camera to be rotated and locked for fixed position shots, or used as a panning device.
Attach to a tripod quick release plate, or directly to the tripod flat base. Either option works.
The light weight of the indiSLDIERmini allows it to be used directly on a fluid head. This allows a quick release plate to be utilized, and also the creativity that mounting the indiSLDIERmini to an infiniately adjustable fluid head brings.
For a step up, there is the indiSLIDERmini Deluxe.
It includes table legs so that the mini can be placed directly on a hard surface and used without a tripod. Imagine the posibilities for close up and close quarter shots.
A pistol grip ball mount allows the camera to be adjusted with the pull of the trigger. After the camera is positioned, the camera mount can be unlocked, allowing 360 degree panning.
The new indiSLIDERmini will give you the ability to carry a dolly in your bag. Wherever you shoot, it’s ready to be used quickly to make great shots awesome!
