New GF1 v1.24 and GH1 v1.34 firmware hack problems
just bought new GH1, brand spanking new in everyway, with the latest 1.3 firmware installed.
same problems as the original poster. i feel your pain!
After trawling the internet, the best guess will be that the new firmware installed on the camera from the factory, negates or is of a version higher than the GH1__132.bin file, hence it cannot be improved upon. which i'm sure is your conclusion here too?
This will probably happen when Panasonic release their next upgrade.(hopefully SOON) and the wonderful community hacks this too.
What confusion! Did Panasonic block the hack? I need to buy one and now there are a lot of people saying the hack doesn't work with the latest factory units... Is that so?
Seeing as how Vitaliy has already tried to make a patch for it shortly after I started this thread... I have confidence that he will continue to work his magic!
What exactly does it mean?
Did Panasonic block the hack or not?
Yes.
I have two GH1's. Older one with ver 1.2 takes the hack; a more recent new body with ver 1.3 doesn't.
Pathetic for Panasonic to do this so late in the camera's production life. :angry:
Finally!!
Finally!!
here we go AGAIN.
FIRST.
Format your card in camera.
SECOND.
Load panasonics firmware in Ptool.
•CHECK VERSION INCREMENT
•AT THE BOTTOM CHANGE THE NUMBER 1 TO 50 (This is just in case Panasonic shipped you camera post-hacked)
•CHECK PREVENT VERSION COMPARE
THIRD
•Click Save firmware
•Save the file in the same directory as your panasonic firmware and click on it
•Don't overwrite, just change the 1.32 to 1.33 your file should now look like GH1__133
•Save
FOURTH
•TRANSFER YOUR NEWLY HACKED FIRMWARE TO THE CARD YOU FORMATTED IN CAMERA. JUST DRAG ONTO THE CARD, DON'T PUT IT IN ANY OF THE FOLDERS.
FIFTH
•MAKE SURE YOUR CAMERA IS OFF, AND LOAD THE CARD INTO CAMERA.
•TURN CAMERA ON AND PRESS PLAY.
•ONCE THE FIRMWARE IS LOADED, CHECK YOUR VERSION. IF IT SAYS 0.0, SUCCESS.
•FROM NOW ON, DO NOT CHECK VERSION INCREMENT, ONLY PREVENT VERSION COMPARE
After having many issues with loading ANY firmware I just followed these steps exactly
and it worked....THANK YOU......
Some time ago someone mentioned that firmware loading is working for him only when dial is in "CUST" mode. When I mod my camera, I always put it in "CUST" instead of Manual Movie mode before switching on the camera and pressing play button. I suppose that it doesn't matter, but you may try it, anyway.
mine is pretty new purchased from Taiwan and arrived last week. it shipped with firmware 1.2
out of the box it was NTSC (said the card I inserted was an incompatable format)
I think the increment I used for Version Increment was 50 (Vitaly's recommendation?)
it wasn't until I ticked both version increment & prevent version compare that it worked.
I am living in Japan and got my Japanese GF1 yesterday. I have not been able to apply the hack with or without the "additional version patch" in ptool 3.40d. Needless to say I have tried the suggestions in this thread as well as variations without luck.
I appreciate the effort of all the smart people and hope for some alternate suggestions.
Thanks.
When I received my GF1 from Japan, it wasn't fully charged even though it says that it has 3 bars, tried hacking for the first time when I got it and didn't work. Fully charge the battery first! ;)
Thanks for the tip. However, I have worked with the battery fully charged, both according to the charger status light and the battery status bars.
BTW: I have tried to enter Temp Service Mode as described here: http://www.dvxuser.com/V6/showthread.php?t=216575 but without luck. The regular user menu states that firmware v1.2 is installed.
26 July 2010: I now succeded in accessing Temp Service Mode and version is indeed: VER 1.24:0000, NO.: F921006240077 etc. like suspected.
Boy is this thread interesting to me!
I also bought a camera just 2-days ago from the 'curry's' retailer in the UK. It also has body firmware 1.3 and I have had absolutely no joy with ptools 3.4
