New GF1 v1.24 and GH1 v1.34 firmware hack problems
I'm amused you haven't yet provided the information he is asking for so he can help you.
Last night I was too tired to do it...today I don't particularly care to.
Already sold the castrated GH1...got a nice new 1.2 version on the way. :smile:
Savart...thanks for your suggestion. That did occur to me. I initially used a class 6 Verbatim then tried again with a class 6 SanDisk and a class 10 Sandisk.
Ozpeter...believe me I was hoping I'd done something wrong. When I posted last night it was 1 am so I wasn't firing on all cylinders. Today I reviewed the procedure. It's reasonably straight forward once the correct protocol is clear. As I said before I would be happy to find out I'm wrong about a firmware lock...but I really think that is the problem.
I'll update when I get the 1.2 version GH1.
Cheers
Hi,
I have put the camera into Temporary Service Mode.
The new version of the Firmware is Ver 1.34:0000
Any chance of a hack for this or should I start to think like others and sell the camera for a Ver 1.2?
DIB
v1.34?
I thought 1.32 was the last official version and then there was 1.33 released as that strange phantom release in Europe?
Hi,
DIB
Ok, DIB, thank you.
I wonder if there is a way in service mode to dump firmware image onto card. ROM Backup I understand is only settings, correct?
Svart, do you have that service manual still? I tried NURBS's link in the other thread, but the file has been removed. It seems.
Hi,
DIB
well there ya go...some proof that firmware has been updated to v1.34 with parameters blocking updates using v1.32 firmware possibly. you can take that crazy man hat off your head now =).
What's concrete? We know that he is running something called V1.34.
That's where our knowledge stops. Did this come from the factory? We don't know.
Did someone do the hack to a camera and return it to a store who sold it as new again? We don't know.
Did the user update the camera and somehow miss that they did it? We don't know.
I don't think anything is concrete yet.
Well, if you enter increment version 2 in PTool I believe it will show the same version number. Battery is down to two lines, so I can't confirm.
If PTool modified firmware version was loaded on DIB's camera he would need to use increment version 3 or higher. It would still be very useful to post the upgrade video just to finally rule user error out.
There has been no official mention of firmware version 1.34 from Panasonic. So let's establish all the facts first before continuing with "adversarial route" discussion.
Hi,
Thanks for all your comments.
I have no hardware to video the actual process but I can go through the stages in detail.
I have :
1. Downloaded the ptool3d.zip file
2. Extracted the ptool3 application. (Also tried with previous versions of Ptool)
3. Downloaded the GH1__V13.zip file from the Panasonic site
4. Extracted the GH1__132.bin file
5. Run the ptool3 application
6. Loaded the firmware GH1__132.bin file
7. Here I have tried many many many combinations. For example.
Click ON Version increment and change the value to say 3. (I have tried many values here ranging from 1 to 12)
Check the actual Version increment check box
Click ON Prevent version compare (also tried this many times unchecked)
Click ON Patches for end users
Check the box for third part batteries. (A while ago I gave up actually trying to change further options until I could get the firmware to update)
Click on Save Firmware
Save as GH1__135 (Again I have tried many names from GH1__131 to GH1__142)
8. Reformat the SD card in the camera. (I have tried 4 different SD cards all different sizes and classes.)
9. Copied the bin file from the computer folder to the ROOT folder of the SD card. (I have used two different computers for the whole process - a desk top and a laptop)
10. Switched on the camera and pressed the green play button.
11. I get the message "NO VALID PICTURES TO PLAY"
I have also tried a bin file emailed to me by another member - same result.
I really hope you can spot an error in the process above, but I think that Panasonics new Ver 1.34 is blocking the update process.
DIB
Does your file when saved have the ".bin"?
Also, are you using a sd card reader to transfer firmware?
Did you format sd card in camera?
Did you reset the camera settings to default in camera?
How did you get the Firmware 1.34? Where did you purchase camera?
from my understanding he has never been able to update the firmware out of the box. it came with v1.34. Svart and svecher has a point though that it could have been a returned unit possibly.
a confirmation DIB's on whether your using usb to camera or card reader would help. usb is known to corrupt bin file on transfer.
For what is worth, my procedure was exactly the same as outlined by dvxdib.
Tried many variations of ptool 3.40d paramerters. Both "increment" and "compare" ticked or only one. Made no difference. Also tried ptool 3.36.
I never use usb for SD file transfer since all my computers have slots. My (former) camera was absolutely factory sealed...it's not hard to tell if someone has buggered around with the seals. I also think it unlikely that the other GH1 and GF1 I tried in the shop were "returns".
When my new version 1.2 GH1 gets here from the US I will try the SD cards which already have the hacked firmware on them. If that works...and it will... things will clarify very quickly as to what's going on.
Guys, stop writing bunch of messsage in hysterical tone.
Go here: http://www.dvxuser.com/V6/showthread.php?t=216575
I want to see this screen items on your "non-upgradable" camera:
On my "non-upgradable" GF1 which can not be updated.
Well, after what Choedo posted, I tried again to get into service mode. No luck. I also tried again w/ hack using Version increment of 3, and saving it as GF1__125.bin No luck there. It looks as though there is a quick flash to a green triangle just before it gives me the "there is no pic" message.
Here is specially for your info:
PTool 3.40d updated
"Additional version patch" added to testers patches for guys with newest Panasonic firmware versions flashed on factory (GH1 and GF1).
