New Flexible LED Panels
Another idea I'm playing around with is trying to figure out if I can add lenses to the 5050 smd lens to make one of these narrow beam...
Please expand.
Theoretically it can be dome.
Practically it's not implementable because of we have no knowledge of the proper lenses for doing it and no way to purchase such lenses. Should we manage to get such lenses, we have no way to mount them, or glue them properly to the LEDs.
I'm not sure I follow what your reasoning. I am talking about buying lenses for standard 5050 SMD LEDs in bulk and attaching them to the LEDs on one of these panels. It would be especially easy since these panels have exposed surface mount emitters. Granted I am not experienced in this specific modification but I know 5050 SMD LEDs are common and lenses designed for them are readily available though not all that cheap if we're talking about buying 256 or 448 of them. Besides cost I don't see any obvious issue with doing this except there is a possibility the effect on the thermals of the emitters may affect their life or quality.
Yeah, they just refunded me. Just before that he suggested the wait might be another 10 days and that I might be able to get a discount for waiting. Not really interested in being involved with such sellers on ebay. Seems like they don't understand what is expected on ebay. If the product isn't on hand, it shouldn't be listed.
Where can you get those lenses? Please provide a link.
How are you going to attach the lenses to the LEDs?
https://www.aliexpress.com/item/LED...egree-high-quality-7-6-7-6mm/32258299160.html
https://www.aliexpress.com/item/100...-30degree-high-quality-7-6-7/32311032707.html
Seems like these may be snug enough to not need adhesive, or just need very light adhesive. Or perhaps they could be added before adding waterproof coating to the panel.
Sadly it seems like these FL-3060A panels are not really available yet for the lowest price. I'm not going to pay $220 for these if they are listed for $150 but it seems the $150 ones are not actually in stock. Seems the lowest priced aliexpress ones are no longer listed as well...
One interesting concern is that there is an amazon review of an FL3060 (daylight) that states it's hardly brighter than the FL3030. I wonder if there is something wrong with the design of the fl-3060's. I would expect them to be nearly twice as bright given the proportional increase in LED emitters and power draw, but I guess we need someone to test that to be sure.
It's suprising that no one has ever come out with a larger sized directional LED light, I imagine it could create a very nice look to have a directional hard source, something like a softbox with an eggcrate but with much greater power efficiency. Even with light diffusion to blend the sources without spreading the beam too much it would likely be much more efficient than diffusing wide-beam SMD LEDs only to have to add an eggcrate to narrow the beam.
Those lenses may fit the LEDs on those panels, with or without adhesive - and the may not fit. The only way to know is to try. That is, to purchase both the LED panels and the lenses and see if the lenses may fit the LEDs, or not.
Yes, which is my plan. I have reason to believe they will fit since they are designed for this format of led.
So for anyone else who got strung along by the Ebay seller:
My light which was supposedly delivered, but never was and was then returned because my address supposedly did not exist and was then re-sent via DHL with a bogus DHL tracking number, which was 'an error" and would be corrected and reshipped again. Are you following so far? Well after a call to ebay,not an email, a transfer to paypal and an updated claim I got a message from the seller today saying I would be refunded. But you have to read the message
Thank you for your kind reply and sorry for all the trouble.
We will refund to you within 24 hours.
Because the refund has to get the manager's approval.
We have to do it according to the rule of our company.
Hope your understanding.
And hope you can leave us five stars feedback..
Best regards!
SO the only reason this happened is because I filed a claim and called. Somehow they were able to keep rescheduling the arrival date so it would prevent a claim from being filed until after that day by ebay and paypal. Mine had been pushed and pushed ...
Ugh well I got a refund at least so I'm sure you will, but no way Id give him positive feedback! He got negative feedback from me for not being truthful about the situation.
Can you test power draw or photometrics? I would like to confirm the Amazon reviewer that said output was no as expected wrong....
I'm getting a reading of 24.24W (~1.01A with the 24V powersupply).
I don't have a proper light meter, but using the android app, Light Meter Tools, I got a reading of 3348 LUX / 311 FC at 3ft. The reading didn't change much between daylight/tungsten (320 FC for full Tungsten).
I'd take all of my readings with a grain of salt. This is the first time I've ever tried to measure power draw or any kind of photometrics.
Anyone know how something like this compares to a Socanland 1x1 bi-color/dimmable? Have a client who has those and they seem pretty powerful (can be used outside in daylight, if relatively close), and apparently accurate (enough for broadcast TV).
Those photometrics sound good if they can be trusted, seems higher than expected but that power draw reading must be wrong... Should be pulling in the 70W range, the 3030 draws at least 40W and does a bit over 100fc at 3ft in my test IIRC so I'd expect/hope for 70W and ~200FC@3ft..
Really depends which socanland 1x1 you're talking about. They make the bicolors 35-100W and 60 or 30 degrees. In either case, LED efficiency is somewhat consistent as is lens efficiency, so as long as you are happy with the way the light handles color and flicker you can sort of just compare power draw beam angle and get a pretty close comparison in my experience. Knowing how color bank dimming happens to be implemented and looking at photometrics helps a lot too.
Photometrics of a panel with no lenses (travor) will always lag behind one with lenses that make it a 60deg or narrower beam (socanland, litepanel, etc) since right there you are focusing the light output by about 4x, but then this advantage may mostly disappear when you want to widen the beam or diffuse the light...
Basically its hard to compare but frankly for my uses most 1x1s are in the 40-100w range and when you consider leds usually get diffused for a number of reasons, they're all within about a stop of output of each other. None will compete with even a small 400w HMI but they all do pretty fine at close range. Still looking for a nice compact and affordable 400-1000w led light... That's the next frontier
Also you guys might appreciate this. I'm in myanmar for vacation and just stumbled across a camera store with all the Chinese gear I've eyeballed from afar as possible additions to my kit. Any gear you've seen I should look for and test if I make it back to the store? The big problem with inexpensive Chinese products is there are many pitfalls and potential design flaws and you can't easily test it without buying so getting to test in store seems appealing here.
Just an update: that seller never shipped to me either, got refund, left negative feedback. Grr. They are still a "top rated seller" though.
