nyvz
Secondly, is there any SIMPLE system for battery powering the 3060s? The Travor FP-550 has been unavailable for quite some time now, and I'm no electrical engineer!
I mentioned it back in the this thread but for fl-3060a and 3030a I usually use my qidian qd-188alt battery pack. I takes 8 18650 cells you buy separately and will output 5-24v which you can select in 0.1v increments. It's a super handy tool to have since you can battery power pretty much anything. I also tested some universal car dc-dc adapters that are very inexpensive and work fine for powering from an unregulated d-tap as long as you get the adapter with a DC barrel plug and then get the d-tap to 5.5x2.5mm barrel cable which is a cable that works on all kinds of common accessories.
Looks like 188alt may have been replaced by a new model: https://s.click.aliexpress.com/e/bn0xB04o
I can't stress how handy it can be to have a ~$90 95wh (once you buy top of the line 3400mah cells) battery pack that has adjustable voltage regulation built in. It can essentially battery power any device you'll come across in a pinch.
