New cameras
Bucknfl
This is a repost that Erich agreed that I could post here. I found it very insightfull and ultimately helps explain why I bought an HMC 150 and not a larger camera.
Buck
New cameras, and where are we headed?
by Erich Roland on Jul 1, 2009 at 6:14:20 am
I posted this over in the Panasonic HPX area a few days ago because it was mostly about Panasonic's P2 format. I thought it belongs over here also because it ask's the question of where both these companies should be looking going forward. I'm not interested in bashing per-se, but to stimulate idea's and conversation about where we are in the "digital time line", how we landed here and where we are (or should be) headed.
When this P2 flash technology came out it was solving a data rate problem for mini cameras. Sony had HDV format converting an existing tape size (mini-dv), and compressing the 1080i HD signal into its limiting 25mp data stream rate. Most were amazed by the image from this pint-sized camera but were unhappy with the compression onto the dv tapes even though the 1/3” 1080 line camera section looked very good. Sony was the “first to market” with the Z1U mini Hd camcorder and enjoyed that market position.
Panasonic was a bit behind the 1/3” HD camera release and took the higher road with a bit rate needed to record to there own DVC-pro codec to flash media. Flash had been out for a while in consumer cameras but not yet in pro (or semi-pro) equipment. At that time the largest (and limiting factor) was that the largest capacity flash cards were 1(one) gb. This wasn’t enough space to record very long segment, (about 1 minute), so you might surmise that this was one of the big motivations behind the idea to package four 1gb SD memory cards into one 4gb “P2” assembly. This way they could also control the quality of the media P2 was born and the HVX-200 arrived.
Oddly (what might have been an omen) the very same point in time the new Macbook Pro’s arrived on scene and had taken the same card slot out of the new laptops that would have made P2 transfer’s much easier. On day one P2 was outdated (interesting). You mean Panasonic and Apple who seemed to be in communication with final cut etc, somehow were way out of sync with this memory format?
Very quickly the HVX was the mini HD camera to own because it was a better recording (dvc-pro) and also matched our Varicam’s format and “look” much better. We all were learning this new “flash media” dance of transferring to hard drives etc, in the fast growing mini-cam market segment.
Many thousands of these HVX cameras were sold, and it wasn’t long after that we started hearing the rumors of a P2 varicam. I’m guessing Panasonic was feeling pretty good about the sales of these 200’s and wanted to parley this fervor into more models, as I’m sure the Varicam sales had slowed (or stopped) because of the HDX-900 release was what many owner/operators where looking for... a buying entry point.
Soon there after the hvx came out with only 4gb cards, the 8gb P2 cards arrived, and then 16’s. The advances in the technology and subsequent drop in price for consumer memory was coming very fast, this is only about 2 years ago, and already 32 gb cards are common, and 64’s are here. From one gb to 64gb in about 2 years, that’s double in capacity 6 times over. Consumer memory needs has been the driver and card capacity and data speeds have improved considerably. The memory prices have fallen to where it’s become a non-issue in the consumer world, yet it’s still a very big issue for Panasonics P2 memory (price gouging anybody?).
Both the P2 and SxS cards are small in capacity and speed relative to where, we need to go in the future. This is where huge advances have taken place in the last 2 years, and Id guess we are in for more big advances going forward, maybe even quantum leaps with Holographic, etc.
The demand for bigger sensors, higher frame rates, bit rates, and transfer speeds is out there but limited by these (already old) consumer “memory stick” platforms. Somehow Red has worked its way around some of these limitations with much bigger sensors, and higher frame rates, and... they were also smart to NOT build the memory receptor into the actual camera body. At Red they understand that this technology could change overnight and they are ready for anything new to come along. (this part is important to save the camera from premature obsolescence, Red's credo)
Panasonic and Sony are currently missing this important concept and have produced systems stuck with the memory technology of today (or actually yesterday) built into the camera/recorders at a time of fast change. Sony and Panasonic both now sell outboard recorders, but are missing the obvious next step which is to design this idea into the system rather then an after thought.
When Red’s Scarlet comes out, and Canon or Nikon begins to solve some of the issues that these new High def DSLR’s have, the Pro world which used to be limited to Panasonic and Sony brands will loose more market to these new innovative digital solutions, market share they can ill afford in this bad economic environment. The big boys must innovate soon, or they may be in much more trouble gong forward. The Convergence Design and AJA both with very interesting offerings that bypass limitations in cam-recorder designs and give us options like the ability to record directly to Final Cut’s “Pro Res” format, bypassing what looks like were un-necessary (proprietary) format conversions in-between.
P2 memory (and SxS) cards “built in” to the camera is an advancement limiter, and Panasonic needs to break out of this already old technology (designed when 1gb was the top end) and jump to a storage platform that has UPSIDE develop-ability with much higher data rates and storage capacity. Sony (with the XD disk) is in a similar bad position where XD is maxed out on speed at 35-50mbs. But Sony is maybe in the better position NOT having lept into 2/3” stick memory camera’s, Sony has been more restrained, and therefore, possibly getting ready for a more innovative move going forward. Sony must break out of the constraints of burning disc's in the field. This "transition technology" can not last, solid state will win in the end, its only a matter of when?
I’m guessing that the flash memory companies are working on the next generation of platforms that have more upside "develop ability". That breaks out of the natural restrictions for speed and capacity of CF, or SD stick limitations. These were designed and built when 8mb was the card that camera with your new digital camera a decade ago. Do you think this medium would look different if designed today? If so what’s stopping the next design?
The next generation might have capacities starting at 50gb, and up to 500 gb or higher, and data speeds measured in GB per sec not MB! What if they cost about what we are used to for spending on tape (or less) per minute of run time, and so we could easily justify leaving the material on these solid state memory sticks as our archival medium (like we are used to with tape)? At this point we will transcended the transfer/achieve issue of expensive flash memory (which is very real problem) and may arrive soon at the place where even the “old school” tape producers will be ready to bail at the next chance to upgrade their camera system and workflow.
I’ve been surprised to see Panasonic put so much stock into this P2 and as fast as they did, dropping tape support (to a degree) at the same time... "but just last year you sold us a bunch of tape products that will last for many years to come!" (what’s with that?). The market coercion that has grown at the same time as P2 is plain to see. If anybody has needed a head replacement in a Dvc-pro deck will notice that the price has doubled in the same time all the new P2 products arrived (Hmmmm) that’s one way to try and manipulate the industry out of tape usage! The marketers seem to be in control at Panasonic and they will pay the price for not being smarter (technically), then the next company rather then attempt to manipulate more sales.
The digital world marches on. Even your basic hard drive that has been with us since the beginning of the digital revolution will soon be on the digital trash heap (along with floppies) as solid state takes center stage and advancements accelerate. In a few years the hard drive will look very “old school“ (and rightfully so). As an associate said to me yesterday "whats the failure rate of hard drives?.... 100 percent! Yes, they will all fail eventually.
These professional 2/3” cameras are built to last for many years. I had my first betacam for about 10 years. I still have my first varicam bought in 2004. My Varicam still works great, looks great and I expect if anybody still wants to use it will still work fine 5 years from now. Even the internal hours counter goes almost forever, but maybe Panasonic has other plans for the demise and shorter life span (trade-in 3700, etc). Does anybody think the P2 Varicam will be viable 10 years from now? Will this odd P2 memory assembly born when one GB was the largest memory size available still live 10 years from now in this fast moving digital world? Or are we in transition phase?
The digital world is advancing very fast. Particularly in data speed, storage capacity and to be stuck with the same memory profile (P2) will likely hold back the advancements sure to be coming soon.
The camera section of these camcorders work very well, and you can see the advances in this “capture” part of the system are slowing relative to the recording. It’s the record/storage side of the equation that’s changing very fast and feels “transitionary”. Who wants to spend 30-40k on a camcorder only to have to trade in for pennies on the dollar to get the next new thing when it’s just the back half that has advanced, and the camera section is more or less the same? These P2 Varicams are an example, where our cameras work fine, and we are being asked to move up to p2, when the capture side is very similar in specs. It’s basically a workflow change, but we have to toss the front end along with the tape recorder because of the one-piece design (hmmm, whats wrong with this equation?).
Red is on the cutting edge with its modular concept. Trade in the camera head for the newer version, and keep the accessories and data storage solutions. It makes us smarter consumers and more willing to spend on the next advancement when we aren’t wasting a bunch of technology that works fine (the camera section), and make an improvement in another part of the system. Its different with a mini cam when the whole set-up just costs 5-8k and getting your investment out is faster and smaller/lighter is the main driver (we understand that mini's are likely only good for a few years). But when were being asked to spend 30-40-60 for a 2/3” camcorder to possibly be out dated in 2 years when they are built to last 10 –15 years... who wants to do that? Add a bad economic environment, and it should be no surprise the P2 Varicam’s are not selling. It’s a HUGE risk to take when we are in transition. We’ve all seen how fast the move from tape has come for this company and we inherently feel uncomfortable spending massive cash because we understand that it can change fast again and we will be left with an out dated camcorder that nobody wants anymore (anybody seen Varicam resale prices?)! We see how this company is cutting out its tape products like a CANCER, and it could happen again with P2 when the next thing comes along.
The professional industry doesn’t trust Panasonic anymore from the last few years of P2 card pricing....marketing ploys, too many models, OVERPRICED products, etc. It feels like they have made bad choices and they are trying to make us pay for these questionable moves.
If Panasonic produced a modular system it would change everything towards moving forward rather then the sales department ruling the roost in questionable products. The customer will feel more in control and comfortable with they’re HUGE investment possibly being worth something 3-5-7 years out because they could replace the section that has made the latest advancement (if they want) and not HAVE to replace the entire cam-recorder because a part of the system that has advanced.
It’s so obvious a problem and solution it seems too simple. I realize Panasonic would love to sell us a new 50k camcorder every 2 years, but nobody can afford it, and it won’t happen. I believe they thought they could force us all to get rid of perfectly good, working tape cameras and buy these P2 products, but they have miscalculated the customer and the industry. Whoever is in control at Pany is missing this important point. They just successfully sold us HDX-900’s and decks by the thousands (from the year previous) what do they expect us to do, dump this new expensive gear already when its built to last for another 10 years minimum?
The Panasonic’s current product line (in 2/3”) reminds me of the poker shows on TV where the guy in the hoody and mirror glasses pushes all his chips towards the middle and proclaims “all in” (on a weak hand). That’s what Panasonic has done with they’re bet on P2. I think they made a huge bet, its not working out (in 2/3") and they need to cut they’re losses (i.e., the 3700 deal). I expect more deals to come with other models, few are buying the 2700 either!
part two follows
part 2
This “Digital Revolution” is truly revolutionary but many people feel constrained by what they have to do t make the P2 work flow smooth for them (because its not ready). P2 is not an idea “who’s time has come”. Lets look towards what is next and I’ll bet then we will see a bigger movement out of tape in a NATURAL transition (not manipulated) because then the tape systems will be a bit older, and the digital storage solutions will be out there.... and it will all work together flawlessly as is required for an “idea who’s time has come”. The move from 35mm film to digital in the stills world happened so fast it was natural and obvious coarse change. So far we are not there with flash media in full size 2/3” digital video for some of these reasons.
Modular is the way forward in professional camera/recorders (I believe) until we can safely conclude that advances have slowed or stopped and the options are few. These big companies need to understand we are in transition and design for this obvious fact. Design a slick system with interchangeable front (camera), and back (recorder/storage). Some would want the multi format variable frame camera head, others just 30 frame and can save money. On the back half, some would want all record formats, others just dvcpro, etc. As Red has done they could even offer the 35mm sensor option into a system of this front vs. rear-end concept approach.
The storage could be chosen also. P2 for those that have a big investment in this media, or the next advancement that’s about to come out in solid state. They could even hang a small 66m tape size tape deck for those that have an investment in decks in they’re edit suit and want to hang on to this way to record (don’t try and force feed your customers). All brought together with a nice, solid, contemporary locking system to mate the front to the rear.
I’m guessing many here remember the large, heavy, ugly 2 piece Betacam Sony still sells today but a 21st century solution to a mating camera-recorder-storage system would be very slick and make the old 2 piece Sony (designed probably 25 years ago) look very sad.
Panasonic and Sony are both unfortunately a bit slow to change (or learn). Look to Red for what’s possible. Red seems to change specs, and designs every other week (for upcoming models) and this speaks to how quickly the advancements are coming in the arena of these motion/digital capture tools we use. Seems we are just at the beginning of what’s to come going forward in this new digital world, and we should understand our position on the digital "time line". These 2 big companies need to recognize, understand this perspective.
Most important right now... the customer needs "investment security" in these big cash outlays the manufacturer's expect us to make. Whether its "trade up" deals like Red is doing, and/or investment PROTECTIVE modular designs. Panasonic and Sony have to solve this basic problem in this fast changing 21st century or suffer the consequences.
Erich Roland
www.dc-camera.com
HD camera rentals, Washington DC
(and Cameraman)
Pretty much right on the money! I've invested in a Nano/Flash unit for this very reason. If a camera has HD/SDI or HDMI ... I can record from the camera no matter what the camera records to!
Exactly, how does the author support this statement?
A modular approach is not always better. It has the advantages that you have stated, but:
1. It's more expensive to produce
2. It can give you ergonomic challenges
3. It can inhibit new technologies because you need to maintain compatibility with the old stuff
There are many products that are not modular. For example cars. If you want a hybrid engine, you buy a new car purpose built around that engine, you don't just get anew engine for your old car.
I'm not saying modular can't work, just that it isn't necessarily better, there are pros and cons for both the manufacturer and the user.
No, they weren't. JVC was first to market. They had the first low-cost HD camcorder on the market almost TWO YEARS before the Z1U was released. The JVC HD1 came out in March of 2003, the Z1U arrived in February 2005.
Not everyone needs, wants, or uses a macbook pro.
[quoteOn day one P2 was outdated (interesting).[/quote]
Ridiculous.
Video editing is a very, very small portion of the overall Mac market, and Apple doesn't add or delete features based on what video editors need. Witness the recent outrage over the MBP deleting the ExpressCard slot, which has orphaned every outboard device that needed access to the bus (and, not to mention, removing the ability to transfer SxS cards).
??? P2 was introduced in 2004 with 2GB cards. The 64GB came out in 2008, so that's a four-year span.
Price gouging? P2 memory has fallen from $2,000 per gigabyte (when first introduced) to $15.60 per gigabyte today. A 16GB P2 card costs LESS than a Red One's 16GB CompactFlash card. And 128GB of memory (in the form of two 64GB P2 cards) cost less than half as much as Red's 128GB RED-RAM recording unit.
Not sure what you're talking about here. SxS is capable of 800mbps transfer rate, and P2 is capable of 1.2GBPS. That's fast enough to store UNCOMPRESSED HD. And 128GB (coming later this year or early next) doesn't seem all that small.
Well, true the memory module isn't built into the body of a Red One, but it most likely will be built into the Scarlet. And I don't think you can even order a Red One without the CF module, so is that really any different? And, having uncompressed full-res SDI output (such as the EX1/EX3 and HPX170/300/500 all do) gives you the ability to use *any* outboard recorder. So ... how can you say Red's prepared for something and Sony/Panasonic aren't?
Er, have you seen the GH1? Seems to have innovated quite nicely and is vacuuming up a lot of the market share that was previously waiting for the Scarlet.
Final Cut Pro's the one with the proprietary format. Sony and Panasonic both record to the open MXF format, and while FCP can use the AJA Ki-Pro's files directly, it's far more interesting to note that Premiere Pro CS4, Avid Media Composer etc, Smoke, Flame, Inferno, Combustion, Grass Valley EDIUS, Quantel, Harris, Leitch, Newtek SpeedEdit, and others can all immediately use P2 files, and many of those can immediately use SxS files. A minor move with FCP should not overshadow what's been happening with EVERY OTHER EDITOR for YEARS.
Why? Because you want them to? Because right now P2 has captured about 80% of the worldwide news/broadcast marketplace. It really doesn't seem like they "need" to break out of anything, their strategy has been astonishingly successful.
This I do agree with, although Sony has found some success with certain types of programs where the disc is currently a more practical solution, such as CBS's "Survivor" reality-TV series.
You mean like making a P2 card that's twice as fast as the old ones, costs 1/3 as much, and (oh, by the way) maintains 100% compatibility with the entire existing infrastructure? That's the kind of innovation that's overwhelmingly consumer-friendly.
You mean like the proposed SDxC cards? That future's already almost here.
SD memory is already almost there. If you use an HMC150 in 6mbps mode, it's already cheaper than DV tape on a per-minute basis. Give it a year and this will be a reality in all modes.
And this, frankly, shows the limitations of an Apple user's perspective on how tapeless is supposed to be. Transfer? P2 was never designed to be transferred. That's how it's used, yes, but it was designed as an edit medium, so news guys could slam five cards in the camera, shoot their footage, and then slap those cards in the five-slot reader and edit immediately. But since FCP prevents that workflow, FCP users don't even get half the potential benefits of going tapeless. Open your eyes and expand your horizons and you'll see that a lot of your "imagined vision for the future" is already here.
Why shouldn't they have gone that way? It has taken them to overwhelming dominance in the high-dollar broadcast world. 75% of the USA, 85% of Europe, and 95% of Asian broadcasters who have gone tapeless have gone with P2. It's been a screaming success.
No, it's not all that plain to see. I don't see anyone anywhere "coerced" into buying one system or the other. What are you talking about?
Hmmm... could that perhaps be because many of those decks have been retired, and therefore service has become more expensive? Hmmm... wonder what it'd cost to get a head replacement on a BetaSP deck nowadays... might want to check on that.
Not sure what you're talking about here. Panasonic has slaughtered Sony in broadcast, they've gone from a bit player to the overwhelmingly dominant force in the last decade. And they did that by making an integrated system that people actually wanted to buy. Not a whole lot of "coercion" going on, for heaven's sake.
Clearly someone who knows what they're doing is in control.
What do you mean by "alive"? Because if you mean will it still be working, the answer is of course a huge YES. P2 cameras have a five-year warranty. Seems like you want to cast doubt/FUD on the idea of the format's longevity. Have you noticed that it's already been here for five years now? And they've just announced AVC-Ultra and they've also announced that they will NOT be changing form factor or abandoning the P2 format. And since they've kept P2 compatible with EVERY PROFESSIONAL FORMAT THEY MAKE (DV, DVCPRO, DVCPRO50, DVCPRO-HD, AVC-Intra 50, AVC-Intra 100, and AVC-Ultra) and that they've announced that the higher speed cards will allow them to innovate new formats in the future while MAINTAINING COMPATIBILITY with the existing infrastructure, it sure sounds like your concerns about transition and obsolescence are WAY off base.
Perhaps you should try aiming those comments at Sony instead, who's introduced and discarded more formats than any other company, and who currently sell three different/incompatible versions of optical disc camcorders simultaneously, as well as supporting memory cards (that record their own proprietary format, again incompatible with the disc cameras) and tape cameras (in various formats). Seems like their strategy is far more akin to what you're complaining about, as opposed to Panasonic which fully supports every format they've been selling for the last 15 years.
1,000% disagreed.
Again, I have to wonder what you're talking about. You do realize, don't you, that Panasonic introduced the HPM110 and HPG20 and advertised them specifically towards existing VariCam and HDX900 owners. These are folks that spent $30,000 to $70,000 on their cameras. Panasonic came up with a $5,000 device that thoroughly modernizes these cameras, adds tapeless recording, and actually lets them become BETTER cameras than they already were (because the P2 AVC-Intra format stores full-raster 1920x1080 and 1280x720 at a full 10 bits, as opposed to those cameras' internal tape drives which stored prefiltered video at 10 bits). So you're complaining about cameras becoming obsolete when a new recording format comes about, when Panasonic specifically made the capability for those new cameras to continue to be used with the new format!
It's like we're living in a parallel world, and Spock has a beard... The HPX3700 P2 VariCam has 1920x1080 CCDs! The capture side isn't similar at all! With the 2700, yes, but the 2700 costs 1/3 what the original VariCam did. And it also records 1080, which the original never did. And it does it tapelessly, at 10 bits, at full raster.
A complete misunderstanding, perhaps? That would seem to sum it up. Panasonic has specifically made a way to NOT toss the front end, just tack an HPG20 on the back, and you're complaining about it and trying to turn it into something 100% OPPOSITE of what the reality is. Sorry, you got this one 100% backwards.
WHAT are you talking about? Just look around, the professional industry has FLOCKED to Panasonic products. They don't trust Sony because Sony introduces and abandons formats. It is specifically because Panasonic has maintained compatibility with their products that has made them so successful! Have you even looked at what's happening out there?
This is a grossly misinformed or just plain malicious statement, but it does not in any way reflect the reality of what's happening in the professional world.
That's exactly what they've done. Don't see where your problem is.
Well, you can choose to believe that, just like people can choose to believe that the earth is flat or that the sun rises in the west. All three scenarios are 100% false, but hey, you can choose to believe it if you want.
Panasonic provided a way for people to KEEP their perfectly good, working tape cameras, and relatively cheaply upgrade to make those cameras BETTER. Can't fathom why you keep asserting the opposite. And with 110,000 P2 units sold, they absolutely didn't "miscalculate the customer and the industry"!
Bro... come on. That's either ignorant or stupid or deliberate FUD. The P2 workflow works extremely well, and its time has clearly come. The Olympics just committed to all P2. Just because someone can't plug a card in their macbook pro ... sheesh, how myopic of a viewpoint are you going to employ? The biggest broadcast organizations in the world have committed to P2, in extreme numbers. Your statement has zero truth in it.
Okay, maybe this is totally solvable with a very, very simple observation: RED IS NOT IN THE SAME BUSINESS AS PANASONIC AND SONY. Perhaps that's where the core confusion is coming from?
Uhhh... right... which is why Panasonic has kept to ONE recording medium, which supports EVERY format, and kept it completely compatible no matter what innovations have come along. How can you possibly have more "investment security" than that?
Right, but in 2004 these were more likely 128MB cards sold for the same money as modern 16GB SDHC cards.
I'd say, in 5 years.
Barry will tell you a zillion arguments why P2 cards are so expensive. Just ask him ;-)
The industry needs to take a breath for a bit and stop acting as Microsoft, demanding more power for every next version of Windows. AVC (and AVCHD) was invented exactly to lower datarate hunger. You can choose XDCAM @ 35 Mbit/s or AVCHD @ 21 Mbit/s with pretty much similar quality. This is progress. Using brainpower is progress. Simply adding more and more and more memory and increasing bandwidth is a brute force approach. Less is more.
Sony is far behind with HDV, it semi-officially relegates AVCHD only to consumer products, forcing its low/mid-range customers into dark ages of tape-based recording (not everyone wants or can afford the EX1/EX3). Expensive CF recorder only adds to Sony's margin. Panasonic shows signs of hope releasing the HMC150 and the HMC40. So Panasonic already have "broke out", I don't see the point of your preaching. The HMC150 uses the same sensor block as the HVX, problem solved (at least for new clients).
P2 is just media, what is important is data. All computer users have got used to it. 12" floppies, 8" floppies, 5" floppies, 3.5" floppies -- all gone. 11-disk mainframe packets of aluminum disk, storing whopping 29MB -- gone. Magnetic drums? Gone. 5-inch HDDs? I don't think they still make them even for servers, though I may be mistaken. Smartmedia? Gone. MO disks? Zip disks? Please, feel free to continue the list.
Media comes and go, but data stays. Data is what is important. You have to have archival strategy, and you have to switch from obsolete media to modern one, and copy your files. As long as you are doing this you will be safe. Do not invest in media. Do not invest in P2 cards. The cards you buy will lose their value in a year, so when you buy them you have to realise that you are buying media for THIS PARTICULAR PROJECT you are having right now, you are NOT INVESTING.
After saying the above, Panasonic and Sony are to blame for locking its users into a single proprietary (for either company) standard. It is funny, that Sony which usually was considered king of proprietary solutions, now offers more flexibility with XxS readers and even with USB access. They should do it in a more open manner and should forgo proprietary standards, or other companies will do it for them.
I fully agree, the system must be modular. Video business is part of IT business now and must play by IT rules if it wants to survive. The cameras must have standard USB, SATA and Firewire outputs and allow offloading files (these are not videos anymore, just files) to any standard-issue storage device that IT uses. Sony again cleary wins with its EX series, providing USB interface with HOST capability. It can read/write from/to any USB device! How cool is that? Now Sony has to work on a beter file system or better yet, this portion should be upgreadable/uploadable. Case it point: my old (now sold) Hitachi plasma TV had Linux core inside, and could be patched and upgraded from a simple USB stick. No need to send the camera to a manufacturer, no need to use proprietary cards.
Hi,
I would say because I know Erich, he has an agenda. He doesn't want to adopt a file-based workflow, he really wants a Varicam with tape and P2 and he wants 1080/60P inspite of the fact there isn't a lot of places you could use that. And the tape plus P2 would make the camera unbelievably expensive. I think and thank Barry for parsing the discussion because Erich's discussion is more about emotion than fact. I actually talk about this in my presentations, much of the resistance to P2 is emotional and not factual at all. Thanks Barry.
Maybe Bucknfl would like to post Barry's comments, with his permission of course, to where he found Erich's discourse.
Point is as much as Erich wants to try and spill the apple cart, the reality is the world is going file-based recording. Pick one that looks like it will be here for a while and so will the manufacturer, learn it and use it, be happy. To do this, look at a manufacturer that has more that 2 -5 products, look at an entire product line and that product line will carry you from Sd to HD, There is only one that does this with over 12 products all centered around the same interface and the same memory.
And this is for another thread, but just because it records to a file doesn't mean it is equal to P2. The rest of the workflow has to be considered and Metadata is huge in a file based work flow. I could go on and on but... that would change this thread to something else. ;-)
Many of Erich's markers are flawed in their research. Post the link where this came from and I will go post a rebuttal.
P2, when you engineer for the future, you get the future. AVC-Ultra anyone?
Best,
Jan
This thread is good enough.
Tapeless of course is not equal to P2. Tapeless means file-based. P2 means fast, expensive, proprietary media. A file is a file, you can save it to any media. If file properties change depending on media than this is not a file-based workflow.
Sony's XDCAM (MPEG-2 HD + metadata + file structure) was initially iplemented for Professional Disc, then for SxS, then for XxS (SxS + SDHC), then for SDHC by JVC. Same files, same directories, same metadata. Please explain, how P2 is so different that this workflow cannot be implemented with anything else but P2 cards? I understand that P2 cards are very fast, so full P2 data rates cannot be implemented for say SDHC, but lower modes surely can. Just like JVC uses a subset of XDCAM EX with SDHC cards. What about USB drives? What about SATA? Again, a file is a file.
HD-SDI interface that Barry mentioned is a video stream link, it is not a file link. Erich was talking about file access, not streaming video.
hey barry that was quite a rebuttal! shouldn't you be using that time on the hmc book!?!?!
i kid, i kid, but really, i appreciated your answer. i always enjoy reading/watching someone rip apart someone's argument with pure fact and logic. good show!
part 2
How the hell does this make any sense at all? P2 workflow is the best thing that ever happened to me and I'd sooner shoot myself in the foot than go back to a tape based workflow. P2 workflow is about the easiest thing to work with out of the box there is.
To what end? RED is not a broadcast camera or a mainstay in the broadcast world. I don't see RED footage splayed across Discovery networks. RED is a cinema camera before anything else. Apples and Oranges plain and simple.
For what? A camera that most people slap cheap glass on the front of and a workflow that requires a means far beyond the simplicity of P2 and DVCPRO/AVC-INTRA? Once again, RED is a CINEMA Camera first and foremost.
When was this ever a problem? If you don't like what you're using change to something you do. Panasonic cameras obviously hold thier value and reputation quite well enough. As far as the future just look at these hybrid DSLR's. This time next year it's anyone's game in terms of technology but at least Panasonic is leading the way by standing by the P2 workflow and giving us great equipment that still uses it, even moving into newer codecs like the AVC-Intra. If you're so put off by the price of P2 and the cameras that utilize it then why are you comparing the established technology of P2 to that of technologies that aren't established that will cost far more than you seem to anticipate. Let alone RED ONE, which is pretty exspensive in and of itself, along with the workflow that goes with it. If you don't like it, don't use it, but don't go and assume that the rest of us aren't happy with what Panasonic has given us. If I wasn't, I wouldn't be using it. No one, not Barry, not Jan, not anyone forced me to use Panasonic and the P2 workflow. I chose to do so because it works fantastic for me and I have not a single complaint about my workflow.
I just sent Erich an email informing him that his post is up here and I'm hoping he will join the dvxuser forum.
Buck
I think Barry and Kamikaze made the point very effectively, so I won't add much beyond this... I could never imagine my coworkers running into the field to do run and gun ENG at 10:30pm on a cold rainy Seattle winter night to cover a murder with any variation of the RED with some sort of modular recording device attached to it. There are still enough old timers around who remember the days when "portable" video cameras meant an oversized camera tethered to a 50lb backpack. That sounds like the RED. It works for what it was designed for-- cinema-- but not everyone who needs a good camera is trying to make the next Star Wars movie. Everyone at my station I've talked to loves P2 and what it's done for us and it's ease of use.
...When this P2 flash technology came out it was solving a data rate problem for mini cameras...
Ummm... no. P2 was introduced first in full sized cameras and was (and is) primarily intended for the broadcast market (i.e. ENG work) in much bigger cameras. The HVX200 and HPX170 were never the intended market for P2.
Well, one, holographic is a ways off. But also, this statement assumes that P2 and SxS are static mediums that will never change. As demonstrated with their "E" series cards, they are modifying and changing the tech in their cards to meet consumer demands. With the advent of SDXC, I'm assuming that it will only be a few years before we see P2 with over a TB of space and higher datarates. I have a hard time seeing Sony not following suit.
Terabytes in size, sure. But higher data rates, probably not much more in the existing form factor, because the existing "E" cards are approaching the maximum transfer speeds of the PCMCIA bus.
However, with a five-slot PCD35 reader, you can transfer multiple cards at their maximum data rates simultaneously, effectively doubling your transfer rate overall. For example, a 32GB "E" card is potentially capable of transferring to a RAID in about four minutes, which is about the limit of the PCMCIA bus speed. But if you put three of those cards in the five-slot PCI-Express-based PCD35, you could potentially transfer all three cards simultaneously in about the same four minutes, taking advantage of PCI-Express's maximum 3.0GB/sec transfer rate. So that's an effective tripling of transfer rate, assuming you had three cards' worth of data to transfer.
Then again, there are other ways to expand the system as well. They could go with what I call "P3", an idea I've pitched repeatedly to them but which they haven't really ever seemed to give serious consideration to. What I mean by "P3" is to use newer technologies but keeping a shell of the same form factor, which maintains current compatibility with every P2 camera, reader, and P2-compatible computer ever sold, while also allowing an avenue for growth and expansion when necessary. It'd consist of an ExpressCard insertable module and a PCMCIA-based cradle, such as this one:
http://www.duel-systemsadapters.com/?productid=DP-0002
With a device like that you could put your new P3 card in the cradle and use it in any P2 system. Or, you could extract the P3 card from the cradle and plug it directly into an ExpressCard slot -- and in a case like that, yes, additional transfer speed could be utilized because the ExpressCard bus is capable of about 2.5GB/sec, about double the speed of the PCMCIA bus alone.
So there are avenues and paths for growth while maintaining full compatibility with today's and tomorrow's standards... I just would like to see them adopt this as at least an option...
The book's in the printer's hands, nothing more I can do about it at this time. And the HMC150 CDs are sitting here, ready to be put in the books... :D
If I had any doubts about getting your book, after seeing your answers on this thread now is a must... I'm getting it! :grin:
Is not that i don't like reading, is just that i prefer doing it on a computer screen and not paper as much :)
I tend to agree, but then you cant throw it in your bag and quickly refer to it in the field. Now an Iphone app would be the way to go for us digital format users. I always have that on me.
As far as this post, some of you have more history in the field then me. But, you also have to consider the advent of new media like AVCHD. We could easily see the data rate (needed) drop since compression formats change often to new better formats. There should always be backwards compatibility to the older versions, except when the form factor must change to something smaller. Now that we are down to the size of SDHC/SxS with the AVCHD Cams it really doesn't need to get smaller (although I thought the same thing when SD came out in a cell phone, then Micro SD came out which made more sense). P2 in general is a tried and true format used by the majority - but its inevitable it will have to change in the future. Will they be nice and give us backwards compatibility? Who knows, that's how they make $$$.
You have to realize a business is 'in business' to make money. We are a 'for profit' economy not a 'resource' based economy. Far to often profit is put way before the customer - perfect example is the Iphone.
Iphone 2g? 3g? 3gs? When the 2g came out other phones all ready had 3g and a video camera. Apple knew exactly what they were doing - maximizing profits and not giving a sh*t about its customers.
Regardless tapeless formats are the only way to go.
