nedcam
I downloaded and installed the firmware update and lost all my settings which would not be a problem except I lost the sheet of paper I had written my preferred settings on! I do remember I brought sharpness down to -6 and Noise Reduction I believe was on 2, the rest is a blank. So I could use some suggestions. I had gleaned my settings from observations on this board, especially Erik's, however, please know this about my work situation:
90% of the time I do not see the footage but pass a drive onto the client or their editor, so I can't shoot flat C-Log since I don't know if there will be any grading. I get great feedback so I felt my settings were optimized for Wide DR.
For instance, under Other Functions, should I have it set at clip at 100%? I ask because I have an Animal Planet show coming up where they are OK with AVCHD and that is a broadcast job. As to sharpness, the first time I used my 70-200 on a haircut closeup of a talking head, an attractive female, I did import and inspect that footage since I was new to the camera and was mortified when I could see her pores with the sharpness set at 0. After that I knew I needed to lower that setting but I didn't feel like going below -6 because I was worried my wide shots would be soft. What is the optimum sharpness setting that doesn't need tweaking per situation?
As to NR, on interiors I rarely go over 1200 ISO (unless it's a doc) so I don't think I need it too high, do I? I can't rely on the post peeps having Neat Video, I want to avoid complaints of creating any extra post work.
I tend to be on documentary style, fast moving jobs so I am not inclined to go in and change a setting for individual situations as I read some posters do, I have my hands full. What would some of you suggest knowing how I work?
So if you have a work style like mine, where every day is different doing corporate, docs and non-fiction TV, moving too fast to tweak settings per location, what Wide DR settings would be most pleasing and require the least fuss in post? Appreciate you sharing your Wide DR preferences.
Thanks!
Thanks!
