Need Import Help P2 cards
I have brought footage in through the P2 slot on my laptop several times. I save it on a G-Raid drive an then bring it in to Final Cut. However the last 3 times when I try to bring the footage in to Final Cut I get a error message that says "Path to P2 volume is empty" plus when I then take the card out and play it on the camera I get a play card error. All the files appear on the card and in the folder on my drive. Can anyone help?
Make certain you are actually copying to the G-Raid and not making an alias?
For example, is the lettering in italics?
Sounds to me like the files on the P2 got corrupted before you dumped them to the G-Raid. Try repairing the clips in camera and then make a disk image of the P2 card in disk utility.
Switch to MCR mode.
select the clip by navigating to it and pressing the pause button.
press menu
go to operation>repair clip.
