Don't worry too much about sharpness; Barry's latest test shows that a softer lens is actually better for video on DSLRs because it reduces aliasing. And don't worry too much about the speed
Did you not read Barry's post, which I linked in my post? Do you not understand why people are slightly de-focusing their lenses and buying the rather expensive Caprock filter, which reduces sharpness?Whoa. Don´t worry about speed and sharpness? Why do you shoot with the 7D then? If you want soft pcitures get a DVX100 and blow it up to 1080.
A sharp 1.4 lens will create far superior images even when stopped down to f4. Look around the web and watch 7D films. All really good films are filmed with at least 2.8 and mostly faster glass.
What do you mean by "all really good films"?
You know, the camera actually only resolves less than 700 lines. So technically speaking, it's far less sharp than an EX1 or HMC40. Any additional sharpness is actually illusory, just perceived sharpness due to aliasing. If you want to increase perceived sharpness, just apply sharpening in post.I meant all good 7D-films on vimeo. Vincent Laforet uses the best glass out there (Canon 1.2 and 1.4), others use 1.4 lenses. It doesn´t matter if it is a Canon L or a Nikon non-AF prime....they need to be fast or the image will be soft to me.
Barry_Green said:I think the image looks better from the softer lens. Which, I guess, does make sense -- aliasing happens when the lens passes too much high frequency detail, and the camera doesn't filter it out properly. A softer lens would be somewhat inherently a bit of a filter, as it would trim off the highest-frequency detail (which is not high-def information anyway, it's just contamination).
So -- heck... shooting with the highest-quality glass you can get may actually be making your 7D/5D images turn out worse, overall! Who would have thought it? You might be able to save a lot of money on glass and get overall better-looking images in the end. Hah!
