but the clip is already like from capture, even while i'm viewing it in the camera's lcd it is already flickering. i'm thingking that there is a certain reason or factor in the environment where i shot the clip that caused the flicker to appear. i wanted to know that reason so i can avoid it next time. thanks.
If you live in NTSC land use 60 shutter speed. If your in PAL land use 50 shutter.
youre right Ted. I tried to take another clip on the same room with 1/50 shutter speed and the flicker was not there.but when i turn the dial either left or right the flicker appears. thank you very much Ted. I learned something new today. maybe simple for you but not for a newbie like me. :-D
