Need help/ info on getting a another camera.
GavinAbe
Hi all ,
Let me explain why I ask this question, currently I use my Canon 550d which I am very happy with and gives me the results and more , I need to get a few cheap camera that shoots in 720p 50 fps for the application for defense industry ( warheads exploding and missiles flights data analysis and to add in to video presentations ) the problem is the only cameras I can get are to are cheap 720p 60fps consumer type camera's ( sanyo vps-L51) or cheap chinese no name brands), I needs to match the 60fps(convert it down) to the 50fps to match the footage of the canon. In most of the case the cheap camera will be destroyed. Will there be any problems with the footage matching ,any advices would be very helpful.
Thanking you
Why would the cameras be destroyed? Is there any way to setup the cameras far away with zoom lenses protected in containers so they will not get damaged? Just an idea...
The reason I go thru a few cameras is the conditions dust ,heat rain etc over a month period or more , the worst is the war heads some of them shoot out 8000 fragment up to 2 km's, the fragments are any ware from 6 to 10 mm's in size also the emp shock and blast wave cause damage, the cameras take hell of a lot of strain and ware.
