Need decent low bitrate
roxics
The last couple times I've shot with my GH13 I've gotten an error saying my card write speed is not fast enough. Even though I am using two different class 10 cards. It has caused me to lose a couple of good videos to the point where I am upset about it. I've been using a hack that is 40Mbps. I need to drop it down to something more sustainable but still decent in quality.
Do you have anything you can suggest?
34 works fine for me and it doesnt drop bitrate when going below 1/50th in 720, also playback in cam too, ive been content with this limit. i have only had one record error (pana class 6 card) at the starting grid of the formula 1, it was a very busy scene =) a quick off on and it was back to normal.
You can try my 24p Event patch, your alternative is lpowell's excellent high reliabilty patch but it is not 24p. A class 10 card is no guarantee, you should test the speed of the card. I have tested my patch with class 6 cards, so if it doesn't work, or lpowell's patch does not work, try a different card.
