So this is kind of a crazy situation, but if you have the patience, read on. I was having some hearing issues and after a test with an audiologist, my doctor gave me some suggestions along the lines "can't hurt to try". According to her, some patients were helped by listeing to nature sounds. Ordinarily, in my leisure time, I listen to music, but the doc suggested that for some people it helps with tinnitis and high blood pressure to listen to gentle nature sounds, such as running rivers, ocean waves, birds in a forest etc.
Anyhow, I looked to locate such recordings, but they all have problems - at least the ones I examined. First, I need something that lasts for many hours, such as overnight while I'm falling asleep and sleeping. Most recordings are 1-4 hours long. Some of the longer ones, such as 10 hour recordings are actually loops composed of 2 hour pieces running over and over again. Unfortunately, I'm very sensitive to sound patterns (from listening to ambient music for years and years), and I seem to recognize and remember if I've heard a passage before, unless it's really pretty neutral. So I need something that is genuinely 10 hours long, or I'll recognize when the same bits keep coming around. Second, of the few 10+ hour recordings I've located, they often have problems such as weird volume drops and other technical issues. Sometimes there are unfortunate events on recordings, such as a fly that happened to sit right on the mic and there's suddenly strong buzzing, and the whole recording I find myself waiting for when that buzzing is gonna come. So bottome line, I need some neutral sounds of nature without human elements, such as airplanes, cars, voices, weird insistent sudden insects that are not typical, and so on, and all this for 10+ hours.
Rather than keep looking, I got the idea of making my own recordings. I'm in Los Angeles, CA, but I can take day trips to nearby places, such as the Angeles National Forest and so on. I thought of the beach, but unfortunately, it's almost impossible to find a stretch of beach for 500 miles around where you will not hear a human generated sound - cars, airplaces, boats or whatnot for a 10+ hour stretch. So recording waves is out.
My idea was to take a trip deeper into the forest, find a spot and set up my gear, let it run and come back hours later. How practical is that? Here what I thought of doing
1)Hike deeper into the forest off trails, where I can be pretty sure there will be no humans for quite a distance around.
2)Set up a tripod with an arm, and affix an omni mic, IN A BLIMP, get a big card, use my DR-60Dmkii or DR-70D with a long-lasting USB battery bank.
3)Monitor with headphones for some time, to make sure that the levels and everything else is OK
4)Let it run while I take off to do whatever
5)Come back grab my equipment and the following day listen to hear what I have
6)Go back a day or two later, and re-do the whole thing, because I'm sure I'll make some mistake or another which will need correcting.
Unfortunately I have ZERO experience doing nature recordings, so I literally don't know wht it is that I'm doing. Is my plan as outlined completely bonkers? Is this doable as described, or am I kidding myself? Thanks in advance!
