I'll probably do a book and DVD and everything, as I think the GH3 has a real chance to be the no-budget DVX replacement we all wanted the AF100 to be
The extensive use of 8x8 matrices (as well as 4x4) in both AVCHD and H.264 GH3 files indicates a major upgrade to its encoder. If it works as efficiently as H.264 encoders used in other DSLR's, the GH3 encoder should be able to produce high quality images using significantly less bitrate than a hacked GH2 requires.
4x4 macroblocks are better-suited to encoding rapidly moving objects. 8x8 macroblocks are better-suited to encoding smooth gradients. A sophisticated H.264 encoder will use both types of macroblocks to achieve the finest quality at the lowest practical bitrate. The GH1 and GH2 AVCHD encoders can only use 4x4 macroblocks, and this impairs their ability to handle gradients without noticeable banding and posterization, even when they have access to bitrates of 100Mbps. The GH3's ability to use both 4x4 and 8x8 macroblocks indicates that Panasonic has made a major upgrade to its H.264 encoder.
After shooting first with the AF100 then going for the hacked GH2, I have yet to see anything from the GH3 that warrants a purchase. I find the images to be incredibly similar to the point that I feel that any visual difference would have to come down to comparing things side by side, in which case, that's pixel peeping, so I'll probably hold off on the GH3. At the very least, if there is a marginal difference, the want for the upgrade will be greater than the need. Which i think will apply to many.
Still very crunchy and contrasty. Surprised they haven't introduced some type of log curve or at the very least parameters for lowering sharpness more than + or - 2, and having to run things through 5DtoRGB is not that fun and lengthens the post process.
I've heard a couple people say something similar to this. So even if the image was exactly the same as the GH2, you're still getting a bigger magnesium alloy weather resistant body, mic jack, headphone jack, clean HDMI out, higher resolution OLED screen, higher bitrates without hacking, MOV option instead of the crazy AVCHD file structure and wifi capability. To me that's a huge difference.
But if the image quality is improved as well, which is said to be, then bonus.
Even if the image quality is the same, it's a better camera. You have an official battery grip, better body build, headphone , better lcd display and most importantly for me 1080p at 60fps + other in camera slow mo..... I can't wait till this camera is released!
The GH3 has a -5 to +5 for each of the options instead of -2 to +2.
Same here it looks like they are using a weak LP filter as I am seeing moiré for the first time in GH footage. I hope that they can tweak that before it ships.Now i'm just hoping that the aliasing and moire aren't going to be a problem on the production models.
