Barry_Green
Moderator
How is the GH1 a "720p native" cam? It has a 10-megapixel sensor. I'm not following what you're saying here at all.
But... do we know that? How do we know that it's not reading the entire frame, and scaling down? Has this been empirically proven somewhere yet?Just speculating right now. We know that...
When the GH1 camera is set to 1080p it has to read 1080 lines.
When the camera is set to 720p it has to read 720 lines.
This does seem like a logical assumption, and typically on CMOS cameras you do get faster frame rates by windowing the sensor (hence why Red's 2K can run at faster frame rates than its 4K). But... again -- do we know it's doing this? Or is this conjecture? Has some sort of test established that this is the way it's working?Using the same clock frequency you can read 720 lines much faster than 1080 lines. That's probably why the GH1 has reduced rolling shutter at 720p, and why it can shoot at a higher frame rate. It can read the frame almost twice faster and has less work to do.
Well, okay, I think I see what you're saying here; on a Red One you can put it in "2K" mode and it uses the central portion of the sensor, but obviously the "2k" mode doesn't hold a candle to its full 4K mode. But: if the higher-resolution sesnor is physically bigger, I think it cancels out what you're saying.In other words, given the subject of the same size. It is always better to have that subject fill as much of the entire frame as possible(to utilize as much of the sensor as possible) versus using a higher resolution sensor and have the subject fill a smaller area of the frame with the intention of cropping the resulting image to achieve the same FOV.
I did say it was my speculation :smile:do we know it's doing this? Or is this conjecture? Has some sort of test established that this is the way it's working?
Right. I agree. But were talking in camera crops or hardware adjustments. The idea proposed here isn't a hardware adjustment it's a software adjust mention after the camera has already recorded what sort of skew it exhibits.
Cropping in post dosnt change anything.
So you use longer lenses to adjust for academy which means jellos exaggerated right? Then you crop it.
But I think I may be thinkIng about it from the wrong angle.
And that's the question... if they used circuitry to specifically link pixels together, perhaps they could read out a row-skipping/column-skipping version, but... what about the Bayer pattern?Programming cameras in the past, the readout has always been a function of the sensor hardware. It's easy to define a window, but to program a sensor to only read specific fields was never available.
Still not sure I follow exactly what you're getting at though. The Canon's sensor is bigger physically, so even though it has twice the pixels, it's also (ballpark-ish as I don't feel like researching up the specs) roughly twice as big, so pixel size should be the same. And therefore, extracting a 1280x720 image out of a 17mm wide crop of a 21-mpix 35mm-wide sensor using 5-micron pixels should be about the same as extracting a 1280x720 image out of a 17mm wide sensor with 10m pixels, assuming 5-micron pixels... should be same-for-same, no? I don't know if the pixels are 5 microns wide, but if one sensor has 2x as many pixels and 2x the surface area, it stands to reason that the pixel sizes would be the same between the sensors, so therefore (using same-size pixels) a 1280x720 extraction from one should be roughly comparable to a 1280x720 extraction from the other, assuming both shots are framed such that the subject is the same size within those 1280x720 frames...
No, you're mistaken. Micro Four Thirds is a "quarter frame" format, so in fact the 5D's sensor is four times larger. Thus, the pixels are roughly twice the size of the GH1's.The Canon's sensor is bigger physically, so even though it has twice the pixels, it's also (ballpark-ish as I don't feel like researching up the specs) roughly twice as big, so pixel size should be the same.
