My humble review of the HMC150
Ed Kishel
How I'm liking it....
I have had it for a few weeks now, and it has allot of strengths. But there are deficiencies as well, which do irk me.
This doesn’t mean I don’t like the cam. This is an excellent camera for the price, not perfect, but very very good! My pros and cons:
CONS:
1. 720 24p looks awesome, however 1080 24p is no sharper. Seems to me the 1080 mode was added so that they could say it does 1080, but it’s really a 720p cam IMO. Add the fact that the 1080 mode might actually loose data based on the size to codec- well, this is my main complaint. It has kind of an "upres to 1080" look and feel. So why even use 1080 then? :huh:
I also hooked the 150 and the cam we use at work- a Sony V1U to a 1080p LCD and compared their 1080 24p modes. Both cams at stock out of the box settings... and sharpness goes to the Sony. Tweaking the detail of the 150 got it close, but to my eye resolution still went to the Sony. Now this was a static focus chart, real world shots would probably show less of a difference.
2. The focus assist could use some improvement. The EVF detail helps, but the focus graph only helps if the majority of objects in your frame are to be in focus. A small item in focus against a soft background and the graph will indicate "out of focus". It assumes all your shots are deep focus, and shallow DOF shots will throw it off. Useless for rack focusing against soft backgrounds. This is where Sony and Canon have the edge- the peaking technique that uses a strong colored outline is much more accurate. The enlarge feature will have to do :)
3. The servomotor for the zoom is loud, much louder to my ear than the DVX100A. Slow to medium zooms are tame, but a quick snap zoom and the onboard mic will pick up the motor during quiet shots like nature scenes. This was remedied somewhat by an external mic, but it became an added cost. The OB mic housing is too stiff IMO, and coupled with the added sensitivity of the mic- motor noise is too prevalent.
4. The SDHC door uses and spring and latch design. This may wear down over time, and if it does, and wont stay closed- the cam will give a "door open" warning. The hard covers/doors of most pro cams use a very small magnet to keep it shut. Works for our 20+year-old beta cam.
5. The "3CCD" lettering on the lens is no longer the laser etched embossed decal (like the Panasonic on the LCD door). Now its been painted on? Corner cutting that looks a bit cheap to me. I will admit this is minor though...
6. Lens hood is a joke; it feels like Tupperware with that corny lid. Should I be listening for that trademark "burp"? At least the lens will stay fresh I guess. Come-on panny- is a integrated lens cap too much to ask on a $3500 cam? Or at least give us the old DVX hood.
7. I know its a tough camera, and it has the magnesium alloy used in Panny Toughbooks- but there is still too much hollow plastic covering the cam. Its most evident on the bottom side- where it will see the most wear and tear? :huh:
PROS:
1. The 720p mode is very very good. If you ignore the 1080 mode, this cam's image if gorgeous. Sony may have the edge on sharpness, but Panny has them beat on color.
2. Low-light capability. Interestingly, when I did my little informal shootout with the V1U, I noticed by accident something very interesting. When I shut off the clip lamp lighting up the chart- and allowed only the ambient light in, the Sony's resolution dropped to well under the Panny. The panny kept its resolution under low light and didn’t flinch. Hmmm :thumbup:
3. Low noise. Not noise free, but very good under low light. And the noise is fine and not a splotchy chroma noise.
4. A wide lens. Although I had to get an external mic for the servo noise issue, I did not have to by a wide-angle adapter. Very cool Panny, thank you!
5. Sharp, big LCD in the 4:3 aspect, which allows a less cluttered screen display. The VF when changed to BW is very good as well.
6. The focus ring is dampened and now feels much smoother. Not as "buttery" as a Sony's, but a big improvement.
7. Histogram, which means under controlled sets you, can use it in place of an external screen. Very cool.
8. 1/4 20 mounting threads on top of the handle for accessories, this will be a big help. And on that note, the handle is thick and beefy (oh my) which feels secure when carrying it around.
9. Focus and iris remote port. This will be a big help when on a boom, or to use for rack focusing with the Manfrotto control knob. Can’t wait to get one! :) The Sony V1U has "scene transitions" which allow rudimentary rack focuses using preset speeds, but user controlled is much better.
10. Tweakablitiy. Most cams in this price range cant match the adjustments you can make with this one. The Sony pales in this regard.
11. AVCHD. Yes it’s a pain during post, but the NLE are jumping on board quickly- with Sony, Edius, and Adobe handling it natively. Panning shots don’t turn to mush, as HDV could never handle movement as well. That focus chart showed that the Sony is sharper yes, but a focus chart doesnt move (and HDV looses its sharpness during movement).
12. Global shutter. No I don’t see many flash bulbs going off, but I do pan very quickly. No more rolling shutter as the V1U uses.
13. And my biggest pro is the tape less acquisition via SDHC. 16 gigs for $30! I can’t stress this enough. You can archive on this stuff its so cheap! With the Sony HDV, you had to get a compatible deck unless you wanted to use your cam. Digitizing sucks, and dropouts suck harder and so no longer do I have to worry about such things.
So in closing, I really like this camera although some of its weaknesses will take some getting used to. I would give it an A-.
It’s not perfect- but no cam is. There are always tradeoffs, and I thinking I have made a wise choice. This camera is starting to grow on me.
shameless plug: I finally got some footage up http://www.dvxuser.com/V6/showthread.php?p=1434723#post1434723
Great review Edweirdo!, I totally I agree with what you said. I loved the comparison between the lens cap and tupperware:thumbup:.
The upper handle is really though!
First thing out of the box i thought was "Man this lens hood seems real cheapo, Where is the lever to flip open the hood shutter?" hahah I'm getting use to it though :)
Thanks for the review Ed!
Tony Cap
Great and honest review! Thanks!
Also, does anyone know a site to buy a modified lens cover with a flip up barndoor like Sony's. If not will any of Sony's work? This is something incredibly important that we need for our kind of work. Thanks!
Great review. An additional pro for me is the very bright LCD - easy to work with the menus even in bright sun.
The only other con for me is that I find that many of the knobs are hard to locate when working through the view finder. I really wish the Iris and Push Focus buttons were larger and next to each other to facilitate shooting in manual. Sometimes I even lose the record start/stop button as its kinda tucked up into a corner.
I want to study your comments regarding focus - I have more to learn there.
Also, I am interested in the Manfrotto remote. Are you referring to the 521PFI? I see it is listed for the HVX-200 and DVX-100B. Does it also work for the HMC150?
EDIT: I just remembered one other con - I wish this cam had a LANC port instead of the proprietary one. Then I could just use my existing varizoom remote.
Jerry
I have to agree with the lens hood...
So much so that I tried to put the lens hood from my FX-1 on the 150 - No dice.
I also can't see much difference between 720 and 1080 but I want to work with native AVCHD before I say one way or the other but for right now with transcoding to DVCPRO I can't see anything major between the 2.
I think you hit the nail on the head here "This doesn’t mean I don’t like the cam. This is an excellent camera for the price, not perfect, but very very good!"
It is a great camera for most and at a nice price point.
It's no Sony F23 but I can't remember the last time I had an extra 150K in the bank!!!
Thanks for your review.
I concurr on your points.
I have had this camera for a week or so and will share my thoughts:
My experience with Panasonic cameras is that you have to pull the image you want out of the camera. Tweak away on a calibrated broadcast monitor to find detail and lower noise.
I have also found that to get the most detail out of the image, I lower in-camera detail settings and apply a sharpen filter in post.
This results in a cleaner image off of the camera and a more comprehensive sharpen application from the editing software (Edius).
The color is fabulous, but I had to push "Chroma Phase" to +4 to get the reds correct, as I have seen with other Panasonic cameras.
I am fine with a 720p camera for $3,500 that is sharp because 1080p to me not that big of a deal since everything broadcast is 720p.
It is not like we are behind the curve....yet!
The lens hood doesn't even have a feaking locking pin to keep it in place. If the hood is bumped a little bit it can cause vignetting on wide shots.
Jerry
yes, this one: http://www.bhphotovideo.com/c/produ...rotto_521PFI_521PFI_Focus_Remote_Control.html
I asked Barry if the 150 uses the same jack as the HVX and 100B and it does, so even though the specs dont say HMC150, the controller is
compatible. (It better be, its to be delivered tomorrow) :)
Great review and all in all those are some minor cons to deal with so that's good to hear. I think it's hard to beat this price and the cost of the cards really is awesome. The way I see it, a full day of shooting with the HMC eliminates a P2 runner and that could add to quite a bit of gig money saved over the course of the year.. probably the cost of the camera I'd imagine.
What I want to see is this cam intercut with HVX and 170 footie.. then it's a clear no-brainer for anyone looking to upgrade. Shoot February will be 3 years with the HVX already.. YIKES.
So.. how is the transcoding to DVCPRO for you guys? Does it take forever?
Using the Panasonic transcoder I find the times are very fast.
I have not timed it to the second but 1 minute of footage takes less than a minute to transcode and DVCPRO HD is very easy to work with on my system.
Still wanting to see what Premiere Pro CS4 has to offer with AVCHD....
I also use the panasonic dvchd pro converter. But my computer is a bit slower, 5:05 minutes take about 7 minutes, but everything depends on your computer.
Edit: now that I see I was using after effects at the same time thus slowing down the computer, I'll have to try without after effects.....
I pretty much agree about the 1080/720 question here. On the HVX/HPX170, I definitely endorse 1080p over 720p for many valid reasons. But on the HMC150, I think it's actually the reverse, and I prefer 720p over 1080p. The larger raster of the AVCHD codec comes close to holding all the detail the 150 can generate in 720p mode, so 1080 is only a little tiny bit sharper. But 720/24p seems so smooth and slick, whereas 1080 doesn't feel quite the same.
So why is 1080 mode there? Why not! When the majority of HD networks are broadcasting 1080, it's nice to be able to generate 1080 footage. But I would tend to use 720p on the HMC150 in most circumstances.
if they both have the same lens and chips, what is it about the 1080 mode on the 170 that is superior to the 720? Is it the codec/bitrate?
thanks,
Codec, yes. The 170's codec retains all its resolution in 1080 mode and is more lightly compressed.
Whereas with the 150, the opposite is almost true - 720p mode retains almost all the resolution and is the more lightly compressed.
I see. How would you compare the 1080 modes of both cameras; a night and day diff that warrants a $1500 price jump? In terms of resolution. I understand there are many ofther features for the price increase.
I understand this might be a hard question to answer without side by side shootout, but what is your general impression?
yessss......p2 is not cheap. if you can afford it, then it is nice indeed. I sold my hvx200a simply cause i needed the long record time. on the fly. without ingesting, etc. the hvx200a was and is awesome. but the hmc's image is also pretty sweet and the media...well...it's cheap enough. it is the dvx in HD. that's enough for me. my humble 2 cents.
that's what i think. It's the media that the killer.. and if I were to do an important shoot and had like 10 hours of footage, the media is so cheap that I could leave it all on the cards for as long as necessary and also have it on the harddrives. Can't do that with P2.. that is too Obama gives all American's a free 16 gig P2 card..
