SHORT: Multiplicity II - Life is a circle
partizansk
Hi guys!
I made my new video where I wanted to put several my selves to interact with each other. Any comments are greatly appreciated.
I was filming this at 7am before my work and didn't notice that the light changed slightly in each shot. The filming took me all together about 10 min but
I was fiddling with the color correction for a long time. I'm not very good at it so please if you can let me know how to match different shots in a correct way.
As always thanks a lot for all your help:2vrolijk_08:
http://youtu.be/44SXivhSiqU
I have tried this a lot, sometimes you can save it with black and white. Before you start cutting color correct whole clip sometimes helps and when its done color correct whole clip as one full movie by exporting and then import and color correct. You cut too quick before asset is out of screen, cropping it can sometimes help, but then you have to do it to the whole clip at start. Know this is just a test run for yeah and know its very hard, night works well when you can control the light but then you have shadows.
You can crop each asset then move the crop as you move and then feather the edges around your crop. But if it only took you ten minutes just re shoot.
Thank you so much for your advice. I will for sure experiment some more with this. Thanks again
I have tried this a lot, sometimes you can save it with black and white. Before you start cutting color correct whole clip sometimes helps and when its done color correct whole clip as one full movie by exporting and then import and color correct. You cut too quick before asset is out of screen, cropping it can sometimes help, but then you have to do it to the whole clip at start. Know this is just a test run for yeah and know its very hard, night works well when you can control the light but then you have shadows. You can crop each asset then move the crop as you move and then feather the edges around your crop. But if it only took you ten minutes just re shoot.
