rbengtsson
Just got my t2i and I'm new to the whole dslr system. Only been using regular dv camcorders before. But I've done some reading up and here's what I do so far.
For example when using a 720p file shot at 50fps.
Bring into mpeg streamclip and export as DNxHD (I'm on pc) and chose the right settings.
Bring into a 24fps project in Premiere Pro cs3. Interpert the footage and change the frame rate to match the project settings.
Bring to the timeline.
This is where I start to get problems.
If I drag my in point of the layer, lets say 1 sec in the entire audio file gets offset. So the audio happens before the action in the video even though the waveform displays it as it was originally (in synch with the video).
If I cut my video, for example at 5sec. The clip before the 5sec mark is fine, audio is in synch. But the clip right after 5sec has the audio offset problem as before and the waveform still shows it as not having this problem.
Any help would be appreciated.
