Samuel H
Major Contributor
I thought I had found a workflow that avoided the gamma shift associated with Apple's MOV (QuickTime) container, but I recently found out that it is very far from perfect...
When I load the dailies into the editor, I don't mind if there's a gamma shift: with the file in a high-bit-depth environment, it's easy to add a gamma correction and get back to something that looks like what I saw in-camera, without any impact on image quality.
Then, I know that exporting from Premiere or After Effects to very high-quality H.264 format (IIRC, the file extension is .mp4) preserves the colors. These files are hard to play back (none of my computers can do it smoothly), but I can then re-encode with Handbrake, to a more reasonable H.264 bitrate and .mkv container. There's an image quality hit because of the extra re-encode, but it's very small if the bitrate of the PP or AE export is high enough. And the final result is an H.264 file in .mkv container that preserves the in-editor colors and gets much better playback on nearly every platform (I think Handbrake is a tool made for pirates, or at least very popular in that world; THEY know how to deliver the product in a user-friendly format...).
And this is where the nasty suprise comes in: when I upload that file to vimeo or youtube, it is re-encoded, the gamma shift happens, and my pretty images look awful (a lot darker than they should).
Case in point, my recent zombie piece; all my beautiful shadow detail gone down the drain...
http://vimeo.com/40741414
(I'm not sure, but I think this didn't happen on vimeo until recently...)
So, my question is: how do you deal with all this?
If you export from PP or AE directly to MOV H.264, the gamma shift happens, but at least you get to see how it looks before it goes online. Right now, I think my way out would be to create two output files: I would create an mkv that looks as it should, with the workflow above, and then add a gamma shift to all my edit and export to MOV H.264 (tweaking so both gamma shifts cancel each other), to upload to vimeo or youtube.
