Are there any decent tutorials/suggestions out there for cheaply mounting a HDMI splitter to a 15mm rod system?
In the past I've used duct tape wrapped around the splitter and rails, however it's not exactly cost effective or stable. The solution has to be extremely low profile and ideally suited for mounting above rails, not below. Similarly, the input & outputs ideally need to be perpendicular to the rails (just to add to the problem).
It's a difficult task from what I can think of. As you can see from the picture itself, there's not much room to play around.
Any suggestions or ideas would be great!
Thanks!
Thanks!
