Hi,
I want to purchase a scrim jim and have a tough time deciding on which is the most useful size for a solo operator. I'm thinking of a 4x4 DP kit, but now I'm wondering if a 4x6 is the more flexible size of the two.
I'd say 8x8 is the smallest you can get and maintain a balance between manageability and versatility. 4x4 can be handy, but won't cover more than a single person for a seated interview.
They're all handy - the smallest size makes a good reflector or to scrim off the sun for an outdoor closeup interview (and it's very easy to fly but sturdier than a popup).
The medium/tall size is handy as a reflector or scrimming off a full-length person, maybe more useful in a studio situation.
The 8x8 is a minimal overhead size (though the 4x8 is often just fine if there's not a lot of movement, and again, easier to fly).
You really need to think about what your uses will be, but the beauty of the system (if we're actually talking Westscott gear, not the chinese knockoff PVC stuff) is you have a bag of sticks and a sack of fabrics that you can alter for many scenarios.
Also, go down to the fabric store and ask if they keep contact info for of seamstresses (actually in my town, retired grannies who make draperies and stuff). You can buy ripstop, net, black mesh, solids, and a ton of loop-side sew-on velcro, and have them make you everything you need for much less. Handy if you want, say, an 8x8 black with a 1" ripstop strip down the middle, or similar stuff Westscott doesn't make.
Get the 6 x 6 kit and never look back. You'll be happy you did. Best additional $180 you'll ever spend.
The times were you find the 6 x 6 too large will be few and far between. The times where you find the 4 x 4 too small will be many and frequent. 4 x 4 as a bounce or diffusion to soften a key light is fine. But too small for an overhead. I have an 8 x 8 Matthews frame that I use for an overhead.
Your instinct to go bigger is a good one because, as my tag line says...
Thanks for your insights. I was thinking of something that I can set up quickly for talking heads. My interviews are usually on location such as homes or offices. The consensus seems to be the bigger, the better....and it's got me thinking
While I do not own the Scrim Jim products, I will say that one size rarely fits all. That being said, I carry 4x4 frames, as well as breakdown frames in 6x6, 8x8, and 12x12. I also carry an assortment of soft boxes and grids for sources smaller than 4x4.
If I recall, the larger grids can form smaller grids as well, so might be worth getting the larger model, and then adding a few of the smaller reflectors/scrims material and build the scrim jim size to fit the need of the moment.
