Hi, did not know what to put up as a subject for this so the one I used is not 100% correct but does comunicate the basic idea.
I did some low light tests with my GH3 and there seemed to be a little noise at the top 3 ISOs. I then did the tests again but this time had a little more light (the previous tests were done with very low light).
With these new test I get no noise on any of the settings. My conclusion is it is not just the ISO that affects noise but the amount of light. I.e. if you have very little light (for a given ISO) there is a highter propensity for noise than if you try the same test with more brightly lit scene. Therefore for true ISO noise tests you must shoot with various light levels as well as ISOs. This means that the test that I often see where different ISOs are tried in daylight only tell some of the story.
This is something I suspected (with my 550D) but now I have done more exhaustive tests with my GH3 I am becoming increasingly convinced it is the case.
What do people think?
Regards,
Ben
Regards,
Ben
