I have 2 LG flatron w2243t monitors that are ok for web videos but anything more than that requires a better monitor of course.
I saw on bh photo a NEC PA242W-BK 24" that seem very good.
what do you guys think?
Doug
Stay away from the Nec monitors.
Bought one from BH and return it right away....
It's not made for video editing but for photo editing.
I had a lot of problems with it on my iMac and FCP X.
Tried to use it with AJA T-Tap and after hours of "chatting "with a NEC representative I gave up.
The guy admitted that their monitors are aimed more to the photo editing.
I bought instead a HP Dreamcolor and never looked back.
Take care...
Thanks Bruce! Until now my work was almost 100% for web (except a few low budget ads for regional tv). But it may change a bit in the next few months. I am working on 2 documentaries that may go to TV (really not sure yet but it's a possibility).
They are not cheap. I cannot justify buying a 3000$ dollars monitor for the work I do. I don't do high end stuff and I don't really need scopes integrated in the monitor because I use the scopes from my software (premiere and speedgrade). Eizo seem to make great monitors too, the CG line seems nice. For sure I will buy at least a 21" monitor. I will be keeping one of my 22" replacing the second with a better monitor...so I want them to match in size.What you perhaps want is called a production monitor, or broadcast monitor (among other names). Lots of companies make them, from Flanders Scientific to JVC, Panasonic, etc.
Broadcast monitors typically offer more tools than just support for the REC.709 colorspace. Tools that help with colorgrading. Like vector scopes, waveform monitors, RGB parades, various overlays, etc. Often some sound tools too. Some are calibrated by sending them back to the factory (usually very rapid turnaround).
I suggest that for colorgrading, you'll want a minimum of a 21" screen. Bigger perhaps. IOW, what you want is sufficient image area that you can see what you're doing. I say this because there are bunches of small production monitors out there for working with cameras at capture time. Useful as they are in the field, I would not want to try to colorgrade on a 7" monitor no matter how color accurate it is. Just sayin'.
They are not cheap. I cannot justify buying a 3000$ dollars monitor for the work I do. I don't do high end stuff...
Thanks, but the Sony PVM monitors are way out of my budget.
Then your best bet is probably a good HDTV that you can have calibrated. And of course some way to interface to it from your computer/NLE.
