nathangrill
im just a little curious about whether or not mojodx was a good purchase for us since we don't have any SDI devices... Any input on what exactly it helps do??
Mojo DX does real time down conversion and DNxHD encode and decode can happen on the CPU when using dual quad.
Michael
With the exception of DS hardware Avid has 3 I/O options for their NLE's: Mojo SDI, Mojo DX & Mojo Nitris DX. Since you're ingesting file based content you could use the Mojo SDI to monitor your output. The downside is that you would be monitoring an SD signal (downconvert) rather than HD. For some users this is unacceptable - they require HD output for signal monitoring (color grading, etc.). This is where Mojo DX fits in, in addition to SDI inputs it has HD outputs. Other users require the extra horsepower of Nitris DX. For example for broadcast work the timelines are often stacked tall (multiple video tracks). The ability to playback multiple streams of HD without rendering speeds up the work flow. When you have deadline to make and ad agency types leaning over your shoulder speed is important.we are using p2 cards and avid works good with them. we will only be putting our final out on dvd/bluray and we have no sdi hardware.
You can get a component to SDI converter box. Decklink makes one for $500.
