has anyone used the mitakon lens turbo with the gh4 at all? If so what is differernce between the Mitakon and the Metabones SB?
Mitakon $150
Metabones $700
Beware! i have the Mitakon Nikon to m4/3 booster and although it's fine indoors and in low light....it is UNUSABLE outdoors in daylight.
It happens when some portion of your shot, that is roughly 5% of the frame or greater, is significantly over exposed/CLIPPED.
CONCLUSIONS:
Of course the Metabones is better even if it's not perfect.
But $430 vs. $135 (For the Nikon to M4/3 version) just simply IS going to be a factor for many people - myself included.
But INDOORS? With any thing even like controlled light? It's fine. It's not going to be a problem.
Even OUTDOORS, many shooting scenarios will not pose any problems.
But in some cases - and common cases at that - it is just not going to work.
One consideration as well is that if you're shooting outdoors on a bright day do you even need a speedbooster? The biggest advantage of using a speedbooster is getting a wider field of view (useful indoors in small spaces), as well as more f-stop and shallower depth of field. But outdoors you can usually position yourself further from the subject and don't need to go as shallow with your DOF to get good background separation, and during the day you're certainly not lacking for light even with a slow lens.
