Your A1 uses frame blending to do that. It's not actually exposing 24 frames at 1/3 every second. That would be physically impossible. The D3s, being a still camera, must not have that function built-in.
if your frame rate is 24, impossible to set the shutter below this value.
You can get slower than 1/24 on your video camera?
exactly because of that. if the camera had been shooting 24fps that would not be possible.Then how come the brightness is double from 30th to 15th and double again to 8th
EDIT: or are you referring to the d3s?
I can go to 1/2 in 720 50p mode on my GH1 resulting in a virtual 2 fps in 50p video file. See 'A Kindling Light' in my sig link.
as I told, it is a TIME LAPS, and not 50p video![]()
but it is. if you record 30 identical frames every second the framerate is 1, not 30. they just figured out a clever way of shooting lower frame rates than the format allows.And you said it's impossible to have a shutter speed below frame rate on a video camera
