What head do you use? Per your comment do you use this head with your 35mm adapater.. can you describe your setup?
Thanks,
Skipioafricanus
I got the Miller SOLO DV20 Carbon Fiber Tripod System from B&H about 15 months ago (having sold my Cartoni F102 on eBay). Used it with both HVX's I had and now a HPX170. I have been completely satisfied with what I have for what I paid.
Hi,
Do you use 35mm adapter or accessories with your HPX 170 on the Miller SOLO DV20?
I was wondering whether the camera is a little too light for the DV20 head.
I'm planning to buy the SOLO DV10 System but really considering the DV20 as I will be ordering a 35mm rig soon.
cheers
I just ordered the SOLO DV10 legs and head. The DV10 head can support up to 10 lbs and the HPX 170 weighs 5 lbs which means you should be able to put a DOF with rails on there without exceeding the weight limit.
