I see. so it seems as if they are basically just UHS-II
http://www.geeky-gadgets.com/wp-content/uploads/2012/04/Panasonic-MicroP2.jpg
http://www.sdxc2.com/UHS-II.htm
The form factor they use is UHS-II SDXC. But the interior contents have the same microprocessor, error correction/detection, wear-leveling, and high-speed raiding of a P2 card.based on barry
its not. the form factor is, but not the content
MicroP2 won't work with the DVCPRO-HD-only cameras (meaning the HPX170, HVX200, and HPX500). It will work on any camera that has AVC-Intra capability. The hardware in those cameras is different. Note, it doesn't have to have AVC-Intra installed (think about an HPX2000) but it has to be capable of having AVC-Intra installed, in order to support MicroP2. So the HPX250, HPX2000, HPX2100, HPX2700, HPX3000, HPX3100, HPX3700, and new HPX600 will all be MicroP2-compatible, although obviously they'll have to use the full card adapter to fit the smaller cards.Why do I get this feeling that Panasonic will shun the HVX200/202 users and say " They already have P2 cards, anyway" and retain the Micro P2 only for newer cameras :-(
Well, you could also say that "any way you spin it, an Audi S8 is just a glorified Volkswagen." You could argue that's true, but I'd argue that it's highly misleading. Volkswagen does own the Audi brand, but there's a night and day difference between an S8 and a Jetta!Any way you spin it, it's just going to be a glorified SDXC card
