mic holder
PaPa
Major Contributor
Wuts up with this thing?
I own both an AT4073 and at4053 mics and neither of these are thick enough to fitt into the mic holder of the A1?
wuts up with this thing?
Got the same problem here, but luckily I rarely use the mic on camera any more. You might just try gaff tape to make it thick enough :)
great, so one must buy something extra to use the mic holder which is intended to work with a shotgun/boom mic.
boo on you canon.
ive got that, its just that it makes the use of my glidecam2000 pro impossible.
damn canon bastards :P
Yup, Canon`s mic holders are pain in the a$$ but you can cut some small and soft rubber tubing to fill the caps between the holder`s holders ad you`ve got a kind of a schock mount. I clued those little soft-rubber tubes with hot silicone so I have standard 19-21mm dimetre mic holder.
Cheers,
T
Yeah size is wierd thats for sure. Easily fixed if you must use it. I use a spare piece of foam cut from my Pelican case. I just cut one that rings the mic about half circumference and hold it on top, push down and tighten screw.
the h1 is the same way, they made the mic holder to be sized for the canon shotgun that comes with the h1. i have to do the same thing whenever i use a shotgun on the h1. def a pain. what were you thinking canon?
