Have had a few PM requests for this of late so here are some images that may be of use when setting up your merlin for the first time with the A1.
First watch the Merlin DVD so you understand what everything is.
These images show a balanced set up. Some arent fantastic quality, but good enough. Note the following:
1/ Weights used and location.
2/ Arc extended to max.
3/ Stage position.
4/ g-platz position
http://www.scarlet-films.com/merlina1/index.html
You can also view my cookbook settings on the Steadicam websiite at this link:
There are two settings, one is incomplete the other says similar size camera HVX200 - these are my settings. Please note the battery used for the set up. I wouldnt use the 970 for this anyway.
http://www.merlincookbook.com/user.php
Once you've done this enough times you can balance your cam in no time. I was tested on this recently and was able to balance three different cameras in under 5 mins each without knowing the cameras actual weight, that's not a brag, that's fact for anyone who spends time with the unit.
Best
Noel
3/ Stage position.
4/ g-platz position
Best
Noel
