In theory, Standard on your 60D should be pretty close to EOS Standard on your C100MKII, but I would do some testing. Jbregar is correct though, the 60D will be much softer.
Honestly my preferred method is to get my 7D as close to my final image as possible, and then grade my C-Log footage to match it.
You really shouldn't shoot "flat" on the DSLR's. They just aren't designed to be pushed/pulled as much as the Cinema Series cameras and things can fall apart fast in grade.
