Canon log on the EOS R is great, so why bother to match it with a non log profile? First, to find out if it's possible, for fun, and second, Canon Log disables Auto ISO. For live shots, Auto ISO is super helpful.
Results:
Waveform after grading with the same Adjustment Layer in PP CC (the before waveform matches as well). If something funky is happening with color, it would not be possible to use the exact same grade on both clips:
Before grading, straight from camera (I've added +1 sat for Canon Log in camera):
After grading with the same Adjustment Layer:
Canon Log requires a higher ISO and even with WB fixed, Canon shifts the WB on Canon Log. The only adjustment in post was a slight Magenta-Green correction.
Can you tell the difference- which is the custom picture style (Filmic Skin updated to match EOS R Canon Log) and which is Canon Log?
The match is not exact, however straight from camera is close enough for my work.
Will also test this updated picture style on the 80D and 1DX II to see how well all 3 cameras can match to Canon Log on the EOS R (as well as to the Filmic Skin / Canon Log version).
Results:
