Ok folks now that we have the new Magic Lantern firmware released for improved audio, where does that leave the H4N ? (Everybody's baby for the last 15 min.) Is the JuicedLink unit going to be the new darling? (You bet they were helpful during the hack process.) What's the new deal?
Would I be able to replace the JuicedLink unit which was used in the Magic Lantern tests with my Beachtek Dual Phantom Adapter DXA-6VU (with led levels):
http://beachtek.com/cgi-bin/online/storepro.php
The argument is that mine is merely a passive adapter:
juicedLink is more than just an adapter
juicedLink is a low-noise preamplifier and a fully buffered mixer.
Camcorder amps are noisy. A better overall signal-to-noise ratio is obtained when the camcorder amps are throttled back, and their noisy gain is replaced with the clean gain of the juicedLink preamplifiers.
Passive adapters can’t do this for you.
Also, adjusting the volume control on passive adapters loads down the adjacent channel, reducing it’s output signal level and further deteriorating its signal-to-noise ratio.
juicedLink’s are fully buffered mixers. So, adjusting the volume control on one channel, has no effect on adjacent channels.
So should my Beachtek go up on the auction block? Should I buy an H4N? Should I go for a JuicedLink?
I will be working in a wide variety of circumstances and my audio needs fluctuate. Short films, talking heads, you name it. I am a newcomer to this audio stuff so perhaps you can give me your perspectives...
