G-Man
Okay, after about a year of deliberation, I finally took the plunge and bought a new mac for my hvx. Prior to doing this, I would only use the mini-dv on the hvx (on my old mac which was a quicksilver I purchased in 2000-I shot 24pAdvanced mini-dv and edited it on a i-movie hd), therefore, I'm completely new to the p2 workflow and am soliciting recommendations. I'm new to this process and I am technologically challanged so please excuse my ignorance.
I have the Mac and downloaded Raylight in order to work with the mxf files natively. I also installed the p2 driver that came with the hvx. I will be purchasing a firewire 800 cable and will be using that to bring over the p2 footage to my computer.
Now, here are my questions/concerns:
1) I had read that one can fry the firewire port on the camera if one plugs in the firewire cable while the camera is on, is this correct? Should I shut off the camera and the desktop, plug in the cable and then turn everything on?
2) I've read Barry's comments about P2CMS. Do I need this program even though I have raylight? I ask because I'm trying to set up the simplest workflow possible and will download it if this will accomplish that-if it I can do it without causing any systems issues.
3) I know raylight will allow me to work with native mxf files, and I've read that you can skip the import procedure altogether with it, but what does that mean exactly? If I connect the p2 card to the desktop via firewire, how do I see it as an mxf file in fcp? What would the steps be once I connect the camera to the desktop? I'm thinking with raylight, I can edit right off of the card, but how do I save the footage to my harddrive?
I'll probably have to look into Noah's workflow dvd to refine my workflow, but I'm trying to get started and I'm hoping to get specific answers to my specific situation.
I guess that's it for now, I appreciate any recommendations/advice.
