iamlance
On a recent small set that I did, I recorded the audio using the Tascam DR-60D. This was shot inside of a house.
When the sound was added to the footage later, I frustratingly realized that the sound volume was quite low. The program and computer volume had to be raised considerably to get the volume to the desired level.
I therefore attempted to match the audio using the waveforms, but obviously, those were quite small and so unusable. I eventually was able to crank up the volume using a plug-in.
Anyone know why the sound level was so quiet?
Specifications:
Recorder:
Thanks guys! - Lance Samples
Specifications:
Recorder:
- Tascam DR-60D
- Rec Mode: Dual Mono
- Gain: Mid
- Limiter: Mono
- Low Cut: 80Hz
- Oktava MK-012
- -10db pad
- hypercardioid capsule
- BBG windshield
