Ian Slessor
How does the 40 compare to the DVX100b in regards to low light performance?
sincerely,
ian
sincerely,
ian
Hey guys,
Here's some more footage from today where we finally had some decent, non-rainy weather with no fog.![]()
This was shot using the Panasonic HMC40 on 1/2000 shutter speed at PH720/60P, starting at 0db gain and going up to 12db of gain. And, slow motion, as well:
http://www.youtube.com/watch?v=4JQHQZMbRLs
Chris
LOL...I agree somewhat pointless, but the shutter speed isn't weird I don't think. When shooting action, at least.that is such a weird shutter speed. and why would you want to use gain on a bright sunny outdoor?
I guess the point of all this was to show people what each respective shutter speed, f-stop, and gain level looked like, so they could compare to a similarly lighted area to the cameras their already using. I found that I could run as high of 1/2000 shutter speed and still be at no gain, unless the clouds rolled in at which point the auto gain control would move it up to as high as 12 db. Obviously, when I lowered the shutter to 1/1000, that wasn't an issue. I hope that makes sense...that is such a weird shutter speed. and why would you want to use gain on a bright sunny outdoor?
The DVX, in progressive mode, is ISO 640. The HMC40 is ISO 64. That means the DVX spanks the HMC40 in low light, handily. You would need about 3.25 stops more light with the HMC40, than you would with the DVX.How does the 40 compare to the DVX100b in regards to low light performance?
Of course, in interlaced mode the DVX's advantage grows by another stop, the DVX is 1280 ISO in 60i mode.
The HMC40 does many things absolutely brilliantly, but low light performance is its major weak spot.
50 to 64. It doesn't get better in interlaced, it's a progressive-only sensor.
