Michael Carter
Just curious - how many of you guys use a low-cut switch or pad (or mixer setting) on set?
I don't do a lot of location sound, but lots of music mixing - and I tend to capture the full range and EQ the lows specifically (and when mixing music, you cut an amazing amount of lows from tracks to leave space for the actual low instruments).
Is there a benefit to not capturing the lows in the first place? I assume a given EQ curve from a high-pass filter on a mic can be pretty exactly replicated with a high pass curve in post - but in post you can dial in the exact low cut you need, not a one-size-fits all switch.
The one thing I've heard in the music world is that the converters can focus their conversion on just the audio coming into the converter, so cutting lows at the mic gives you a subtle smoothness to the highs - but most engineers want the full range for raw tracks. (And I imagine studio-quality converters at 24bit or higher have no problem with the extra bass).
Just curious, after several threads here weighing gear pros & cons and "no low cut" being a deal breaker for some...
