LoveFest 2008 Voting is now OPEN
Hey guys if it helps this is the stuff at the top that keeps popping up when i try to log in and vote. I know i have over 100 posts, and I submitted a film...as far as I know I'm eligible to vote . Anyways heres the message:
"Warning: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 's Evil Twin', 'http://www.dvxuser.com/V6/image.php?u=26822', '189', 'Y', 'Y', NO' at line 1 in /home/.malin/fest_admin/dvxfest.com/private/_lib/Db/Db_MySql.class.php on line 198
Warning: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1 in /home/.malin/fest_admin/dvxfest.com/private/_lib/Db/Db_MySql.class.php on line 198"
Dustin - thanks for the error message, now I know what the problem is ... I believe I've corrected the issue, please try again.
I got logged in and it says I only have two post!!!
I know that is wrong. Someone please get that fixed. Who do I contacted?
Zim, I fixed your entry ... you should be able to vote now ... sorry for the inconvenience.
I'm now working on the issue where those with less than 100 votes, but who entered a film are unable to vote ... should be done sometime today.
Thanks Robbie, but that was just a test title to fix a bug in the voting login code ... now back to my preferred title.
If anyone else has can't vote because you have less than 100 posts, but you entered a film, please PM me directly so I can modify your user record to allow you to vote.
Thanks,
Larry
Please be aware - there is a problem with the database server at the moment which may prevent you from voting. I am working with the host provider and will get it back up as quick as possible.
Rock The Vote!
Rock The Vote!
Let's get as many people to vote as we can. One way is to make sure they know it's crunch time - time to see the rest of the films and VOTE.
Here's some banners.
Paste 'em in your sigs or make your own!
I made 'em small so you can rock 'em next to, above, or below your current banner. If you make your own and still want to keep your current banner, don't make the vote banner too big.
To paste them in your sig with a link to this thread ...
  • hit the quote button onthis post,
  • then right click either of the above banners,
  • select copy,
  • close the current window by going to your control panel to edit your sig
  • then paste the banner in your sig.
Follow those steps and it will carry the link code that way. If you just copy the banners from above without quoting first it will just carry the image.
