You wouldn't be able to use the touchscreen as a touchscreen with a loupe on it. Maybe that isn't a big deal if you are using the C200 shoulder-mounted since you wouldn't be able to use it that way so easily anyway.
Another consideration if you were to use it shoulder mounted is how difficult it may be to get the loupe situated properly in front of your eye. Actually it seems unlikely that you could use a z-finder loupe on the touchscreen, they probably aren't the same screen size -- and Zacuto seems to make things difficult to adapt without using their products for the fairly specialized uses they were intended for.
I have a Zacuto EVF pro, which is the Zacuto monitor and loop attached. I haven't experimented with trying to use it in a shoulder mounted situation, but it isn't going to be a simple matter getting that thing way out in front to meet your eye on the C200. There have been a few threads on this subject, and I remember someone who explained how he was able to use the Z-finder, but it may not have been an ideal setup. That said, there's probably a way that's cheaper than getting a Gratical. Maybe the Zacuto Axis Mini (but is $400+ ?)
Hi guys,
Wondering what people's thoughts are on simply adding a loupe (like the Zacuto Z-Finder) to the touchscreen, versus using a dedicated EVF like the Gratical.
Are there any standout pros/cons to one or the other?
Cheers
When I'm really operating, I want a real VF. Most of the loupe set-ups I've seen and used are a hindrance.
