Log and Transfer HELP!
r1ck
I hooked up my camera using FireWire and it shows up on the desktop. I then copy the files to another folder. But then when I go into FCP, it says that there is nothing connected thru FireWire. Then I go into the Log and Transfer window and it shows nothing is connected and the eject button at the top is greyed out. I then go to add new folder and click on the folder on the hard drive that I copied and hit Open on that folder that contains the TXT file and the CONTENTS folder and hit open and get nothing imported.
I did get files earlier this morning in the Log and Transfer mode but only when the camera was turned on and connected. When I disconnect the camera, I am not able to add a new folder in Log and Transfer..
Thanks in advance for any help..
Are you actually copying the intact mounted p2 volume, or creating an alias of it?
How long does it take to copy that mounted volume?
Does a green "+" sign when you make the copy?
I am copying the files (No alias) it takes minutes to copy the files. I don't know about the green + sign.. Where is that?
