AC160 live recording & avchd recording
Ok, I kinda have the same question, but I have been unable to find the correct answer. The HDMI output on the 160 is at 8 bit at 4:2:2, what does the SDI sample rate output at? The reason I ask is I am looking to see if I can get higher than the internal 4:2:0, by using an external recorder like a Ninja or Samuri. So any idea, I have looked at every spec they have and no luck.:Drogar-Shock(DBG):
Do you think we can make a sticky about the HDMI/SDI output and its differences between AVCHD recording? Please...
live recording setting vs avchd recording setting whats the difference?
If you have it set to the recording, your audio will come through the Headphones with a slight delay. You do have confirmation that it has been recorded.
If you have it set to LIVE it will not have the delay.
Hope this helps,
Jan
