What is the best light meter to get and for the best price? Need one that will last.
I primarily use a slightly older Sekonic Cine all-in-one for convience, but last I checked the spot meter didn't read as deeply into the shadows as a dedicated Spot Meter, or was quite as accurate in incident mode as a Spectra.
There is no fixed standard for metering. The ISO specifications give a range of possible calibration constants.
Different brands can read differently and all be "correct" to their specifications. Gossen, in general, will give the shortest exposure, and Minolta the longest. Sekonic is in the middle. Differences can be as big as 1/3 EV.
This is a nuisance but doesn't really matter that much because meters should be used with understanding of the characteristic curve/transfer curve of the capturing medium. Exposure should be done for a specific meter + camera transfer curve combo. Besides, two correctly working meters can be matched with the help of correction values. Any decent meter has these.
Part of any initial use of meter+camera should be a calibration test to see if the indications match up with the photographer's style, or desire. I use to rate Tri-X still film at 200, rather than the manufacturer's 400. That was based on exposure test that gave me 'what I wanted', relative to my printing process...
I few months ago I read that in around 1960, most films were given a 'doubling' of their previous ASA ratings... based on the new speed rating standard...
FYI, when shooting digital a meter should only be used when lighting, for checking ratios and such. Camera exposure should be set by looking at the camera's image using either a calibrated monitor or exposure tools such as histogram or waveform.
I disagree. If you have calibrated the meter and the camera together, the meter can reliably be used to set exposure. I've been getting great results with the Alexa, Epic, C300, 5D, & GH2. I'll of course double check what the in camera meters are telling me. But 99% of the time I don't have to change anything.
What about the other 1% of the time? Because something CAN be done most of the time, doesn't mean it's the best way to do it.
I think you missed the part where I said that I double check the in camera meters. That is what protects me that other 1%. The meter is great- but it's not recording the images.![]()
Sure you look cool checking your meter and then calling out a stop, but that's really just posing.
My point stands - light meters should not be used to set exposure with digital cameras.
Why not just use the camera or monitor image and associated exposure tools in the first place then, since you are going to look at them for this purpose anyway?
You are adding an extra step for no reason.
I have LOTS of reasons...
Did you read my posts, or is this just a knee-jerk reaction because you feel I insulted you?
None of which are setting exposure on the camera. I already said that light meters are useful for lighting tasks. What they should not be relied on for is setting camera exposure.
