AlainAlain
Lexar cFast card not recognized bij Camera and Mac
this is a huge problem, I had a shoot for a whole day with unreplacable footage
3400x on a C300M2 I shot on 1920/1080
I use Lexar 3500x and haven't had any issues. The 3500x are officially approved for the C300 Mark II by Lexar; the 3400x are not officially approved by Lexar. Neither Lexar cards are officially approved by Canon; Canon has only officially approved the SanDisk.
I do. Lexar is a reputable company. If they officially approved a card for a particular camera, would you not think that there was a reason they did so? You think they're just making up out of thin air that the 3500x cards are compatible with the C300 Mark II?Who cares UNLESS they are approved by CANON?
Since when do memory cards need to be officially approved by the camera manufacturer anyway? For all of the past memory card cameras I've used (Canon DSLRs, GH2, C100, HMC40, EX1, etc.) we tended to use a wide variety of cards without ever checking if they were "officially approved" by the camera manufacturer. Why would the C300 Mark II be different?
In the meantime, us early adopters are taking risks...
Thnak you for all the reply's, but is there software to recover my data? I know there is for photo's, but is there for this material too?
I meant us early adopters are taking risks by using a new camera which hasn't been field tested over the course of a year or years. New cameras often have issues when first in use, hence early adopters take risks, not just with regards to what memory card they choose. Even Philip Bloom returned his Red due to reliability issues which from what I gather have since been solved for the most part. Yet, yes, of course I use the C300 Mark II on paid shoots.Eric Coughlin said:In the meantime, us early adopters are taking risks...
I hope you're doing that on your own time and not with paying clients.
Right. So you're basically saying that Lexar, a company that you consider reputable, has said the 3500x cards are compatible with the C300 Mark II, not because of any legitimate tests or data they have on the matter, but purely because they wanted to sell cards which you're saying have a high chance of failure since Canon has not officially approved them. Or in other words, the "reputable" Lexar is not in fact reputable, despite you just saying they are reputable, and that they are basically trying to make some quick money before people figure out their 3500x cards are faulty in regards to use with the C300 Mark II.First off, yes Lexar IS a reputable company. I have used and still use their cards in my still cams.
Now, what reason can you think of for Lexar saying their cards will work? To sell cards. Yes, it's that simple.
I know not all cards are the same. The only point I was making is most cameras work with a wide variety of manufacturers cards (even if some manufacturers are known for having more reliable cards), and most cameras do not release "officially approved lists" of what manufactures cards they are compatible with, so the C300 Mark II is different in that regard. That is, unless I'm unaware that all previous memory card cameras have had official lists of approved cards released with the camera. I know some do, like the Black Magic Ursa Mini, but I'm under the impression most don't, such as the C100.And unless you've been been living in a cave for the last five years, you should know that all memory cards are not the same. I'm not an engineer, but all memory are not manufactured the same, "wired" the same or have the same type of controllers in them. The C300 mkII isn't special.
Someone posted a video of the testing procedure that, I believe Sound Devices, goes through with media. It's pretty impressive. I can't see a third party media manufacturer doing the same with each individual device that their cards may be used in. The equipment maker has more at stake to make sure their equipment works.
And even that is not enough! Delkin CF 32GB 700X which was bundled with Sound Devices gear (and with AJA gear too). Worked perfectly in the manufacturers' equipment, failed miserably in various card readers. A lethal combination of very high failure rate and approval from a company that is highly trusted. Took a very long time for Sound Devices to hone up and specify the Serial no range that was affected.
Bottom line is: You have to test all the way! Not just recording device! Particularly for memory cards that don't have a Write Protection Switch! Like CF and CFast...
Sorry to derail discussion.
